Fast Joint Precision Joinery System - Router Forums
post #1 of 14 (permalink) Old 10-24-2010, 08:24 PM Thread Starter
kschouweil's Avatar
First Name: Kevin
Default Fast Joint Precision Joinery System
Hello all,
Has anyone used the MLCS Fast Joint Precision Joinery System? My wife saw it in one of my magazine and wants me to buy one to join contrasting colored woods into boards with the heart template. The ads only show the hearts in a standard half-blind configuration. Looking at it, I believe it would but I would hate to buy it and find out it can't.
Thanks,
Kevin
kschouweil is offline
post #2 of 14 (permalink) Old 10-24-2010, 08:44 PM
Hi Kevin
It will do many, many, many of them but keep your CC card handy it's not a cheap system..
see video on the same web page
Also see the link below and video
http://us.oak-park.com/catalogue.html?list=RTS-LDS-
Originally Posted by kschouweil View Post
Hello all,
Thanks,
Kevin
post #3 of 14 (permalink) Old 10-24-2010, 09:14 PM Thread Starter
kschouweil's Avatar
First Name: Kevin
Thanks!
post #4 of 14 (permalink) Old 10-25-2010, 05:29 AM
xplorx4's Avatar
First Name: Jerry
Greetings Kevin and welcome to the router forum. Thank you for joining us, and remember to have fun, build well and above all be safe. I have looked at it from time to time, just need extra funds!!
Lamentations 3:22-23
xplorx4 is offline
post #5 of 14 (permalink) Old 11-08-2013, 02:14 PM
jeepered's Avatar
First Name: Ed
POOR REGISTRATION! I'm having trouble with my male and female pieces fitting together properly. When I attempt to make a boxtop with the joint running lengthwise along the center of the boxtop the male and female pieces do not mate. Both the male and female pieces appear to be short and too wide. I cannot join the two pieces without destroying them. When I overlay one piece over the other they appear too be short. I can see that a space (gap) would occur between the end of the receiving female cutout and end of the male complement. Even if I were able to join the male and female pieces, the respective pieces are too wide (fat) and if I were to force one over the other (ie., male piece forced on top of the female piece with a hammer) the male piece would leave an impression on the female piece at it widest point.
If any one else has had this problem I sure would like to hear from them and how they solved it. I believe that the fault (error) is mine but I just haven't been able to identify it yet. Could my error be in faulty centering of the cutter in the bushing????
Please get back to me.
Thanks,
ED
Last edited by jeepered; 11-13-2013 at 09:01 PM. Reason: Deleted email address as advised
jeepered is offline
post #6 of 14 (permalink) Old 11-13-2013, 08:01 AM
jeepered's Avatar
First Name: Ed
Hi Kevin and welcome,
I'm new to the zoo too. If you are curious about the "Fast-Joint . . .System" contact Peach Tree (that's my next step). I spent over $500 with MCLS over the past 2 years and am STILL trying to get a decent "end-to-end joint. I believe the templates are not matched properly. Check out MCLS at (800) 533-9298 and ask Lisa or Debbie to patch you to the head tech guy, Jeff and see if you can get some definitive answers from him. I couldn't. When I do contact Peach Tree I'll let you know how successful I was.
Thanks,
ED
jeepered is offline
post #7 of 14 (permalink) Old 11-13-2013, 08:38 AM
First Name: Duane
Ed, yes indeed you will have fits getting a proper joint of that type if the bit is not accurately centered in the bushing. Seems a much more likely cause than an inaccurately machine template.
Dmeadows is offline
post #8 of 14 (permalink) Old 11-13-2013, 09:07 AM
CharleyL's Avatar
First Name: Charley
I had the same jig, but the one sold by Woodline. It's also sold by Peachtree. Each company has a different name for their jig, but the design is the same.
If your router collet is not perfectly centered to your router bushing you will not get joints that fit together. You must use a bushing centering tool to get the collet and bushing centered with respect to each other and you need to check this centering frequently. Peachtree sells a wave washer to help hold the nut on the Porter Cable type bushings tight.. If the bushing loosens during your cut your joint will not fit together. If you change the router depth setting this may also cause the collet and bushing to no longer be centered. They must be perfectly centered with respect to each other for this jig to work properly.
Charley
Central North Carolina
CharleyL is offline
post #9 of 14 (permalink) Old 11-13-2013, 09:08 PM
jeepered's Avatar
First Name: Ed
Tried it again Duane with a different router and paid special attention to centering the cutter in the bushing. You are correct! Even though this last attempt of mine was not perfect it was within 90% of being acceptable. I noe believe I'm on the right track and eventually get it right! I'll let you know.
Thanks,
ED
jeepered is offline
post #10 of 14 (permalink) Old 11-13-2013, 09:19 PM
jeepered's Avatar
First Name: Ed
Charley,
You are right on! After eliminating all of the possible mechanical error possibilities and being certain human error was not a factor (ego got in the way) I humbled myself and concentrated on me centering the cutter in the bushing. I got very close to "on center" this last time (within 90% acceptability). This is the best joint I've produced so far. I've tried all of your suggestions and I must confess now that the fault is mine. I'll let you know when when I get the joint to fit perfectly.
Thanks,
ED
jeepered is offline
Fast-joint Joinery System Echonav Jigs and Fixtures 15 12-29-2012 05:06 PM
Sold: Incra Router Table Fence LS 17" Joinery System Mahogany Man Woodworking Classifieds 1 11-09-2008 09:01 AM
New and curious about Oak Park box joint jig system ncparolelady Jigs and Fixtures 3 10-06-2008 10:01 PM
Outlook Express problems BrianS Lobby 6 01-06-2008 07:23 AM
