Changing a Miter Saw Blade - Router Forums
post #1 of 22 (permalink) Old 10-30-2010, 08:00 AM Thread Starter
First Name: Ken
Default Changing a Miter Saw Blade
Hello,
I borrowed my son's miter saw and bought a new blade for it. I'm sure the one on it is the original 40 tooth so I got a 60 tooth blade as I want to do some finer work, not just framing.
It's a Delta 10" model 36-070 and I figured there would be a manual online. The only one I could find is in French but I could see from the pictures what I needed to do. However, when I got the cover off and tried to loosen the old blade it is Extremely tight. I don't want to break the bolt that holds it on so here's my question: does anyone know if the normal way these are attached is with a normal thread or is it a reversed thread? I know they all have differences but I'd bet this is something they have in common.
Thx,
Ken
sepulchre is offline
post #2 of 22 (permalink) Old 10-30-2010, 08:10 AM
Gene Howe's Avatar
First Name: Gene
My miter saws are all reverse thread. Not sure about yours or others than the brands I own.
Surely someone will chime in with an answer relevant to Delta.
Gene Howe
Snowflake, AZ
Gene Howe is online now
post #3 of 22 (permalink) Old 10-30-2010, 09:29 AM
HI Ken
Get your air impact out, put the right socket on it and tap the button, it will come right off. they are left hand threads the norm..if the blade is on the left side of the machine..
Don't forget the Golden Rule, Lefty Lucie, Righty Tighty but in this case it's the other way around, Righty Lucie ...
Originally Posted by sepulchre View Post
Hello,
Thx,
Ken
post #4 of 22 (permalink) Old 10-30-2010, 10:14 AM Thread Starter
First Name: Ken
Yes, it's a reverse thread (I spoke with a few tool repair shops). Unfortunately, I don't have an impact wrench. Maybe one of my neighbors does.
Thanks for the info.
post #5 of 22 (permalink) Old 10-30-2010, 10:26 AM
DGK
First Name: N/A
Send a message via Skype™ to DGK
Remove the blade bolt clockwise.
oops...I was a little late
DGK is offline
post #6 of 22 (permalink) Old 10-30-2010, 10:33 AM
HI Ken
It's one of the tools you want to have in the shop , they can be used for many jobs in the shop.. ,.like driving in big lag screws..
1/2" Electric Impact Wrench
post #7 of 22 (permalink) Old 10-30-2010, 11:15 AM
Hi Ken,
There is usually a pin to press to lock the arbor from turning. Take the arbor bolt off with either a wrench or a 5mm allen wrench (depends on bolt to hold blade on). Remove outer flange then blade & reverse process. You shouldn't need an impact.
Look at teeth direction when replacing blade but usually the label of blade is on the bolt side so you should be able to read it. The teeth should be down & towards the fence when rotating.
Whittier, CA.
Have a nice & safe day!
jlord is offline
post #8 of 22 (permalink) Old 10-30-2010, 01:34 PM Thread Starter
First Name: Ken
Thanks everyone. Can't get an impact wrench . . . yet. Next toy is a table saw. Sears has a nice one (very solid fence, laser, nice stand) on for about $230. So the wrench will have to wait.
As a side note: My wife's being very kind about all this. She started by clearing out our shed. It was her father's workshop and she wants to see it used again. She went out yesterday and bought me a shoplight, and clamp light and materials to insulate my little shop. While at Sears we saw the table saws and while I was looking at the cheap stuff she pointed out a much nicer model saying, "Next payday." So adding more tools will take awhile. That's okay; I have friendly neighbors.
post #9 of 22 (permalink) Old 10-30-2010, 03:36 PM
LexB's Avatar
First Name: Lex
You can get a manual impact driver pretty cheap. It uses impact sockets, but you whack it with a hammer. Just buy the size impact socket that you need and you're still under $20 USD for the whole shebang. I used one back when I was in high school (and too poor to afford anything else) to remove cylinder head bolts from my car, etc. Just keep your eye on the ball so that you don't miss and hit your hand. Been there, done that.
LexB is offline
post #10 of 22 (permalink) Old 10-30-2010, 04:21 PM
Ralph Barker's Avatar
First Name: Ralph
Default leverage
A pipe slipped over the end of a (properly fitting) regular wrench will work, too, adding the leverage needed to break the bolt free.
- Ralph
Ralph Barker is offline
Best Scroll Saw-Easiest Blade Changing jrprottas Wood Scrolling 57 01-19-2014 08:18 AM
For Sale: Ridgid 12" sliding miter saw - USED, works dovetail_65 Woodworking Classifieds 11 01-20-2011 11:28 PM
Bosch 5412L 12" Dual Compound Sliding Miter Saw and T4B Folding Stand Combo CanuckGal Tool Reviews 8 07-24-2009 01:19 PM
"Lo-tech" table saw blade alignment simplenik Tools and Woodworking 4 04-10-2009 12:27 PM
table saw blade selection blurry Tools and Woodworking 19 03-13-2009 12:12 PM
