8mm collet adapter vs 8mm collet - Router Forums
post #1 of 23 (permalink) Old 11-03-2010, 06:21 PM Thread Starter
First Name: Todd
Default 8mm collet adapter vs 8mm collet
I recently purchased some 8mm dovetail bits and it came with an 8mm collet adapter. My question is should I purchase a dedicated 8mm collet or will the adapter suffice as these are the only 8mm bits I own. My concern is can the adapter damage my 1/2 collet?
toddpolo14 is offline
post #2 of 23 (permalink) Old 11-03-2010, 08:24 PM
Hi Todd,
If the adapter is made by a reputable manufacturer for a 1/2" collet, there should be no problems.
I know a number of members use 8mm and 1/4" adapters in their 1/2" collets.
Sydney, Australia
jw2170 is offline
post #3 of 23 (permalink) Old 11-03-2010, 08:27 PM
Hi Todd
The adapter will Not damage the 1/2" collet... (8mm = 5/16" shank router bits)
post #4 of 23 (permalink) Old 11-04-2010, 03:07 AM
istracpsboss's Avatar
Country: Croatia
First Name: Peter
Hi Todd
The adaptor is unlikely to damage anything, but bear in mind that the grip will be slightly less than that of a dedicated collet, so avoid heavy cuts.
Cheers
Peter
istracpsboss is offline
post #5 of 23 (permalink) Old 11-04-2010, 04:07 PM
Phil P's Avatar
First Name: Phil
Personally I'd only use a collet adaptor as a last resort. As Peter says they grip quite a bit less strongly than a correctly sized collet which means that on medium to heavy cuts you can experience bit slippage, so sometimes the bit will move up or down in the collet. As I'm generally routing as part of my living that's obviously a complete no-no.
Phil P is offline
post #6 of 23 (permalink) Old 11-04-2010, 04:46 PM Thread Starter
First Name: Todd
Thank you everyone for your expertise. I think based upon the feedback I will purchase the additional collet due to potential slippage.
post #7 of 23 (permalink) Old 11-04-2010, 05:07 PM
Just my 2 cents
Some of the funny routers are setup to use the 8mm shank router bits, the ones over the pond the norm..some of the router bit sets are made just for the 8mm bits ,like the one below, I'm sure if they would damage your router they would not sale the adaptors.
As far as "slippage" I don't think so, they make many types of "adaptors" the best ones are the ones with the 3 or 4 slots in them and they do hold the router bits in tight..
This dovetail set below includes all the router bits needed to use for Leigh D4, D4R and D1600 Jig to make drawers, chests, or any other project.
16 pc 8mm Shank Dovetail Router Bit Set For Leigh Jig - eBay (item 140474120341 end time Nov-10-10 22:19:26 PST)
http://www.mlcswoodworking.com/shops..._bearings.html
http://www.leighjigs.com/cutters-d4.php
Just a bottom note,,,Out of many,many routers I have not one of them is setup to take on the 8mm (5/16") shank router bits..and I would be hard press to find them for sale in the states..
post #8 of 23 (permalink) Old 11-04-2010, 10:01 PM
RJM60's Avatar
First Name: Robert
Bob is right. A decent adapter won't slip. Besides, you could just tighten it a little more than usual and it will be fine.
“The single biggest problem in communication is the illusion that it has taken place.”
George Bernard Shaw
Robert
Redondo Beach, CA
RJM60 is offline
post #9 of 23 (permalink) Old 11-04-2010, 10:43 PM
Hi Todd - If it really bothers you, you probably get collets for your Freud's fairly easily, possibly for the Bosch and Ryobi.
John Schaben
jschaben is offline
post #10 of 23 (permalink) Old 11-05-2010, 03:49 PM
Country: Croatia
First Name: Peter
I have the same 8mm set from George, with the adaptors, although being this side of the pond, I'm using 8mm collets and not the adaptors.
A dedicated collet has either 3 or 4 independent fingers depending on the make, which enable maximum gripping power.
The adaptor has three slits, only one of which goes all the way through. (If they all went right through, the thing would fall apart). It therefore fits only where it touches and when tightened, is limited in its movement by two of the slits being only partial and thus attached to their neighbour and moving in tandem, not independently. It relies on the inner circumference reducing as it tightens. However, the inner circumference of the individual segments remains constant and any change is a bend at the point of the partial slits, which is not optimal. The grip will even vary depending on where on the adaptor the collet fingers are pressing.
Mostly it will work, until the day the cut is a bit heavier, or the feed rate a bit faster, when the reduced grip will allow the bit to move when a dedicated collet would have held it.
I must admit that I don't know why this particular 8mm set is being offered by George for a primarily US market, although I was glad to get mine. I only wish he'd offer more 8mm shank stuff ,as he is far cheaper than anything otherwise available over here. There are times when something more rigid than 1/4" but not as big as 1/2" is handy, particularly if I don't want to use the bigger routers.
Cheers
Peter
Craftsman Quickrout 1/2" collet adapter lwbox CNC Routing 7 05-01-2011 09:56 PM
Collet adapter or chuck for a 5/8" keyed shaft TanOak Table-mounted Routing 11 06-14-2010 05:43 PM
8mm collet for PC7518? btracey1 General Routing 3 01-12-2010 11:30 AM
Having trouble with 8mm router bit adapter bushing namans Router Bits - Types and Usage 4 09-22-2009 06:40 PM
slipping bits in collet adapter Gene Howe Router Bits - Types and Usage 4 01-27-2009 03:42 PM
