Straight Cuts with Scroll Saw - Router Forums
post #1 of 8 (permalink) Old 11-08-2010, 01:57 AM Thread Starter
kolias's Avatar
First Name: Nicolas
Default Straight Cuts with Scroll Saw
I want to cut some 1x 14 long strips of 1/4" UHMW and aluminum with my 16 King Scroll Saw. The cuts must be straight and I was thinking if I could secure a piece of 1x 2 on top of the saw then it should be fine.
Since the underside of the table top is ribbed and its difficult to secure the 1x 2, I was thinking to drill two 1/8 holes on the table top to secure the fence.
Is it a good idea?
Nicolas
kolias is offline
post #2 of 8 (permalink) Old 11-08-2010, 04:53 AM
Hi Nicolas,
I am not sure what other saws you have, but I would have thought there must be an easier way than to use a scroll saw for ripping.
Sydney, Australia
jw2170 is offline
post #3 of 8 (permalink) Old 11-08-2010, 05:49 AM Thread Starter
kolias's Avatar
First Name: Nicolas
I have a table saw James but don't like the idea ripping with it UHMW and aluminum in such a small size. The scroll cuts both really good but need a fence to get it straight
Nicolas
kolias is offline
post #4 of 8 (permalink) Old 11-08-2010, 07:05 AM
First Name: del
i belive it is going to be hard to do. The blade's don't have teeth on both side's. They are punch out and only have teeth on one side .I belive only on the right side. That is why when you saw anything the piece want's to pull to the right. Call Mike and ask if he has a answare. He sell's the best saw blade's Flying Dutchman the link Mike's Workshop selling Flying Dutchman brand fret and scrollsaw blades
del schisler
port st. lucie, florida
del schisler is offline
post #5 of 8 (permalink) Old 11-08-2010, 07:33 AM
BearLeeAlive's Avatar
Nicolas, with the proper blade, table insert and push sticks, cutting that material on the table saw would be a piece of cake. I routinely cut stuff was smaller than that.
JIM
BearLeeAlive is offline
post #6 of 8 (permalink) Old 11-08-2010, 12:27 PM Thread Starter
kolias's Avatar
First Name: Nicolas
Thanks Jim but Im not an experienced user with the table saw and Im afraid of kick backs. I do have the proper blade, insert and push sticks but I dont cut anything less then 3 strip on my table saw.
The other reason is that my blade guard is too wide (came with my cheep saw) and if I go less than 3 the darn guard touches the fence and then I cant use the push stic. I will do no cuts without the guard.
Im sure that the scroll saw will do a nice job because I did some experimental runs and it cuts beautifully but obviously I cant get a straight cut without a fence
Nicolas
kolias is offline
post #7 of 8 (permalink) Old 11-08-2010, 01:05 PM
Hi Nicolas
It can be done on the scroll saw with the right blade,,it's not one of the thin ones but it's hvy.and wide blade, call Mike he will tell you what blade will work ..
But you will need to replace the blade many times,, the teeth will ware on the blade on the right side quick..and will want to move off to the right side easy..
Like the number 12 that's .067 thick.
Originally Posted by kolias View Post
Thanks Jim but I’m not an experienced user with the table saw and I’m afraid of kick backs. I do have the proper blade, insert and push sticks but I don’t cut anything less then 3” strip on my table saw.
The other reason is that my blade guard is too wide (came with my cheep saw) and if I go less than 3” the darn guard touches the fence and then I can’t use the push stic. I will do no cuts without the guard.
I’m sure that the scroll saw will do a nice job because I did some experimental runs and it cuts beautifully but obviously I can’t get a straight cut without a fence
post #8 of 8 (permalink) Old 11-08-2010, 03:28 PM Thread Starter
kolias's Avatar
First Name: Nicolas
Will do that bobj, thanks
Nicolas
kolias is offline
PORTER-CABLE 16" Variable Speed Scroll Saw with Stand Noob Wood Scrolling 18 03-03-2012 06:01 AM
Plunging straight bits crquack Router Bits - Types and Usage 17 04-16-2010 12:25 AM
straight bit / spiral bit (solid carbide bit?) hyiu Router Bits - Types and Usage 3 04-13-2010 09:09 PM
Dado cuts on bookshelf djmoss Table-mounted Routing 2 11-25-2008 09:41 AM
Help identify scroll saw & Band saw Kristin D Tools and Woodworking 11 11-29-2007 09:11 PM
