Delta CTS and Unifence Deal - Router Forums
post #1 of 14 (permalink) Old 11-08-2010, 02:03 PM Thread Starter
First Name: DJ
Default Delta CTS and Unifence Question
Hey all, I've got a chance (and wife's permission) to get an absolute killer deal on a Delta Contractor Saw with a 30 inch Unifence on it (to replace my borrowed Ryobi finally). It appears the owner stores the unit without the extension's legs intact. Will this mess up the precision on the Unifence system from sagging?
mtnmaniac is offline
post #2 of 14 (permalink) Old 11-08-2010, 03:30 PM Thread Starter
First Name: DJ
Added a pic just in case.
post #3 of 14 (permalink) Old 11-08-2010, 06:31 PM
allthunbs's Avatar
First Name: Ron
Hi DJ:
Interesting discovery. If that "cabinet" is metal the rest of it looks good. Be prepared to do a full setup and realignment anyway so I wouldn't worry about it being stored in pieces. Does he have a manual? If not, Delta Machinery|Porter-Cable will have copies.
Allthunbs
allthunbs is offline
post #4 of 14 (permalink) Old 11-08-2010, 08:40 PM Thread Starter
First Name: DJ
Originally Posted by allthunbs View Post
Hi DJ:
I will check on this. Thanks for the heads up!
post #5 of 14 (permalink) Old 11-08-2010, 08:50 PM
MikeMa's Avatar
I have seen 30inch wings w/o legs so you should be fine. I'd so go for it.
MikeMa is offline
post #6 of 14 (permalink) Old 11-11-2010, 06:33 PM Thread Starter
First Name: DJ
I bought it since it was so cheap, and anything seems an upgrade from the borrowed Ryobi I've been using, which has now also stripped, so my blade stays up. Here's the verdict. I'm no expert on finer table saws tho:
Original owner's manuals for both the saw and unifence were available.
Owner admitted to doing absolutely zero maint ever, and also claimed only occasional DIY hobby use... Several pieces of furniture, exterior millwork, etc.
The motor and all that appear to be in great shape. All paint in great condition. Absolutely zero rust on most of the unit, including the metal "cabinet", except for minimal surface rust on the trunnion? and similar bare metal parts (benefit of a CO climate I spose). Moving parts definitely need cleaned and lubed, if lube is SOP specified. Supposedly the belt is original , but doesn't have any fraying, cracking, or other excessive or irregular wear. It ran nice and quiet. There was zero blade wobble or motor play cutting or pushing and turning with hand.
It has a WWII 40 tooth TK blade in it, put on when bought. It's never been resharpened, is pretty dirty, has a few chips, and needs some TLC, but to my eyes looks useable, except for the chips. It cuts ok, although in retrospect, I should've tried harder to find some scrap oak or hickory maybe to test with, not the SYP 2x4. Hopefully is salvageable for a reasonable price, but if not, I guess I've got one heckuva utility blade. Anyone care to speculate on costs I might be looking at? I'm gonna be ashamed taking such a neglected blade in for reconditioning.
The Unifence extension table has some considerable wear from being moved too much, and too carelessly, apparently. There's a big chunk missing where the center bracket underneath ripped off. The laminate is peeling along the edges, and the brackets appear a little bent. The top surface is still pretty decently smooth I spose. Not sure what the owner cut with this thing over its lifetime, but there are a few deeper than fine, parallel sliding scratches/gouges on it and the cast iron table top.
Besides the left wing needing alignment, the cast iron tabletop seems in useable shape. The sliding scratches bug me, and depending where, I can see less than 1/64" of light beneath a straight edge in front of the blade.
The Unifence seems in good shape aside from some wear and tear from the moving around. It also appears whatever the heck the sharp objects (screws?) were got ahold of it a few times.
It also came with the factory throat plate, and two aftermarket zero clearance masonite? plates (one for dado and one for regular blade). The original SideKick blade was also available in used condition.
At this point I look forward to restoring and using my find. Will see how things pan out. Any suggestions and hints are appreciated. ...time to start making progress
post #7 of 14 (permalink) Old 11-11-2010, 07:40 PM
Hi DJ,
I was going to recommend a new blade until I worked out that
a "a WWII 40 tooth TK blade in it" meant a Wood Worker II, not
a World War II blade. ROTFL.
It sound like you are going to have fun with the upgrade...
Sydney, Australia
jw2170 is offline
post #8 of 14 (permalink) Old 11-12-2010, 09:42 AM
Ralph Barker's Avatar
First Name: Ralph
I have a couple of old Delta 9" contractor's saws. While not as sturdy as a cabinet saw, they are perfect for me, having a small shop where everything needs to be movable. I have a Delta T2 fence on mine, rather than the Unifence, however.
One suggestiond I'd make is to replace the old V-belt with a Power-Lock twist belt - those orange belts with removable twist links. It will run much smoother.
- Ralph
Ralph Barker is offline
post #9 of 14 (permalink) Old 11-12-2010, 12:54 PM Thread Starter
First Name: DJ
Originally Posted by jw2170 View Post
Hi DJ,
Lol, that EXACTLY what I thought WWII stood for for awhile! It all came together when I visited the Forrest site
post #10 of 14 (permalink) Old 11-12-2010, 12:55 PM Thread Starter
First Name: DJ
Thanks for the tip! I'm open to any ideas learned from experience.
