Venner raised panel - Router Forums
post #1 of 3 (permalink) Old 11-08-2010, 03:19 PM Thread Starter
Default Venner raised panel
I need to know how to meke a venner raised panel
kikin1096 is offline
post #2 of 3 (permalink) Old 11-09-2010, 01:04 AM
Ralph Barker's Avatar
First Name: Ralph
Do you mean a veneered raised panel? (That is, a raised panel on which thin veneer stock is glued?)
Raised panels are usually made of solid wood, glued up to the necessary width, if necessary. Applying veneer to the raised panel (e.g. one made of MDF) would be tricky, to say the least, but possible. I'd see it as a multi-step process, with a lot of very careful trimming in between.
- Ralph
Ralph Barker is offline
post #3 of 3 (permalink) Old 11-09-2010, 07:27 AM
Hi kikin1096
It's not that hard, you can use paper back "venner " stock, use some good glue and two roller one small one and one very small and short, and you need a spray bottle of water to soften the wood veneer you can't have any real sharp corners they must all be rounded off so to speak.. use can also use the paper type that looks like real wood it works very well also..with a good wax job they will turn out fine..and last a long time..
Here's a snapshot of one..it's just some MDF with the paper type on it.
Mitered raised panel doors bobj3 Table-mounted Routing 13 09-03-2010 12:37 PM
help with raised panel bits ccmnova Router Bits - Types and Usage 28 08-19-2010 09:11 PM
Raised Panel End Grain Question. AlanSweet The Finishing Touch 6 05-17-2010 08:32 PM
Wainscoting Raised Panel jerry45 New Member Introductions 3 08-11-2009 08:56 PM
What size of Raised Panel Bit? SandyT Table-mounted Routing 29 07-17-2006 10:34 PM
