Old wood planes old #7 & #8 Bailey - Router Forums
post #1 of 14 (permalink) Old 11-10-2010, 09:15 PM Thread Starter
Jack Wilson's Avatar
First Name: Jack
Default Old wood planes old #7 & #8 Bailey
I was recently at a sale where this guy had several old LARGE wood planes and several Bailey #7 and I think 1 #8 plane. Not really sure what I was looking at or what they were really worth. I don't use hand tools like this, but I wouldn't be opposed to it, just not comfortable with it at all. So, I guess I am asking what recommendations ya'll might have and what these tools are worth.
I can see myself digging a trench in the top of a piece of wood I am trying to plane, so I never went down that road.
Jack
He is no fool who gives what he cannot keep to gain what he cannot lose
If you cannot stand behind our troops, (and I understand, no judgement here), then please stand in front of them, remember, they're willing to stand in front of you!
Jack Wilson is offline
post #2 of 14 (permalink) Old 11-10-2010, 10:12 PM
First Name: Curt
Hi Jack,
Fine Woodworking just came out with their annual issue of Tools and Shops, in it you'll find a great artical about tuning up your old bech planes. You could learn a lot from reading it. Also if you look around on Ebay you'll be surprised by the price range for some of the planes.
I recently bought a new low angle block plane for $76.00 and if I had checked on Ebay first I could have got it for under $30.00 plus $8.00 S&H and I've seen others selling for more than they cost new.
Have Fun,
Curt99
curt99 is offline
post #3 of 14 (permalink) Old 11-11-2010, 07:14 AM
TwoSkies57's Avatar
Jack...
you were looking at a couple of 'jointers'.. the big boys of hand planes. These are used for smoothing out large surfaces such as table tops and edge jointing. The difference between the two is minimal with the #8 being a couple inches longer than the #7. Preference between the two comes down to a personnel choice. Both are rather hefty and require a bit of effort to use. Both will provide on heck of a work out!!!
As far as worth goes. Thats a loaded question. It all depends on just how good a condition the plane is in. Some are nothing more than a parts donar. Others in NOS condition can be worth well over 300.00 to a collector. Purchasing one off of the bay can be a crap shoot unless you buy off of a reputable seller who gives an accurate description of the plane for sale. A good "user" could go for anywhere from 50 to 150 bucks plus/minus. sometimes ya overpay, sometimes ya get a deal....Another "big" consideration is which "TYPE" of plane it is. The bailey's are indentified by type, from 1 to 19. 1 being the earliest version, 19 generally considered the last of the quality planes made under the stanley bailey monikor.
things to look for:
Sole of plane is FLAT!!! especially around the mouth. You can get away with a couple .000's at the heel and toe but around the mouth, the thing needs to be flat and true.
Mouth needs to be clean and square.
Tote and knob (handles) should be in good condition. Major cracks and splits will require repair or replacement. Both are readily available and relatively affordable.
Body of play should be in relatively good condition. minor pitting and/or rust really doesn't effect performance unless its extensive.
Adjustment knob needs to be freed up and work in both directions.
Chip breaker should be in relatively good shape, most notably where the chip breaker rests against the iron. this portion needs to be in really good shape in order to apply even pressure against the iron. Otherwise, it can usually be cleaned up easy enough.
Iron should be in good shape, most notably around the business end. A great plane with a lousy iron won't work worth a crap.
The frog should be is good shape. The plane iron needs to rest on it nice and flush, you need to be able to adjust as needed.
Lateral adjuster needs to be functional if equipped.
bottom line, if you can find one to just tinker with, its worth it to have and a blast to get to learn how to use. A well tuned #7 or 8 has a limited scope of use in a small shop. Considering the amount of use it will most likely get having one is more a novelty than a necessity.
HTH
bill
Skipper the Penguin
TwoSkies57 is offline
post #4 of 14 (permalink) Old 11-11-2010, 07:42 AM
Hi Jack
Buying planes is like buying a 2nd car for your own,,it's nice to have one but you will spend most of your time just looking at it/them, put your money into power tools that do the job easy and quick..but if you like to make a mess in your shop the hand planes are for you...
post #5 of 14 (permalink) Old 11-11-2010, 11:48 AM
First Name: Warren
Default make a mess in your shop
Hi Jack
Hahahahahah. You got it Bob. I've had fun the past several weeks learning about,fettling and using some planes. I will have a use for a couple of them. And I have made some wonderful and aromatic messes. But I gotta tell ya, after doing a couple small rabbets with a Stanley #191 I concluded I can walk over to the router table, mount a bit, and do the same thing in a few seconds of actual work!!
But I WILL agree....there is a magic in working wood with hand tools. I LIKE a couple of the planes and wood knot (??!!) be without them and my little pull saws.
Wood knot......neat huh? haaahahaha
sourdough is offline
post #6 of 14 (permalink) Old 11-11-2010, 07:40 PM Thread Starter
First Name: Jack
Default Let Me Clarify
Some the planes were MADE of wood, I see that I wasn't clear in my descriptive narrative. I found the wooden planes interesting, intreauging even, and they were as large as the #8. I wonder what anyone may know about them.
Thanks guys & gals
Jack
post #7 of 14 (permalink) Old 11-11-2010, 07:50 PM
TwoSkies57's Avatar
Jack...
The wooden version (assuming they were not japanese style planes) are known as "Transitionals". Mfg'd primarily during war era to save on metal. Functionally they are about the same as a standard all metal plane. In fact, there are those who would much rather use a transitional any day of the week. They are cool!! Espeically when you find one with good wood. Nice thing is that the wood bodies can easily be squared and/or replaced if needed. you can usually find pretty good deals on these. Some of the larger transitionals can hit 30"s in length and longer.
Skipper the Penguin
post #8 of 14 (permalink) Old 11-12-2010, 07:05 AM
allthunbs's Avatar
First Name: Ron
Hi Jack:
There's nothing more frustrating than a dull plane. Learn how to sharpen it and it will be one of the first tools you reach for. Routers are great but it takes a plane to take the "routerness" out of a joint, but only if it is realllllllllly sharp. I'm setting up the sandpaper-based scary sharp system. That also holds for cabinet scrapers.
Allthunbs
allthunbs is offline
post #9 of 14 (permalink) Old 11-12-2010, 08:34 AM
Hi Guys
I can't think of a tool in the shop that will dull up quicker than a hand plane, you can dull the cutter on a hand plane by sitting it down wrong on the work bench plus it just takes one good knot ,that's it's ,,,dull ,,, that's why the router bit will put most hand planes to shame,,carb.tip router bits will stay sharp for a very long time unlike the blades on hand planes..
post #10 of 14 (permalink) Old 11-12-2010, 09:34 AM
Ralph Barker's Avatar
First Name: Ralph
Thanks guys & gals
I believe that wooden planes are also traditional in Scandinavian woodworking. Although usually made by the woodworker, there are a couple of commercially-made brands still available, as well. James Krenov, for example, is well known for advocating self-made wooden planes.
In the U.S., Clark & Williams is keeping the wooden plane alive.
Clark & Williams - Our Planes
Adjusting the depth of cut is done with a small hammer. A light whack on the front advances the iron a touch, a light whack on the back end retracts it a hair.
- Ralph
Ralph Barker is offline
Introduction to Wood Species... BobandRick Wood Species 40 03-19-2015 12:03 PM
woodline ebony wood planes kp91 Tool Reviews 3 06-28-2011 07:16 AM
Need help with wood planes!? sourdough Tools and Woodworking 35 09-16-2010 07:01 PM
Framing a small piece of wood lea6141 Table-mounted Routing 10 08-19-2010 04:01 PM
A Wood Experience-Contest Woodworkers Source Contests Archive 2 05-14-2009 05:58 PM
