Central Machinery Lathe - Router Forums
post #1 of 2 (permalink) Old 01-21-2011, 10:11 PM Thread Starter
jimini2001's Avatar
Default Central Machinery Lathe
Hi folks, I just got a Central Machinery lathe (freebie) and as it isn't much as lathes go. I was thinking of converting it to a shaper sander or...? Does anyone have any suggestions? I was thinking of taking the tool rest off and making a table top to replace it with. I haven't quite figured out how to attach the sand paper. I was thinking of attaching velcro to a round piece of wood and using six inch hook and loop sanding disk but I am not sure that would work. Well it is just in the planing stage so any ideas would be appreciated.
Thanks,
Jimi
jimini2001 is offline
post #2 of 2 (permalink) Old 01-22-2011, 02:22 AM
Ralph Barker's Avatar
First Name: Ralph
Depending on the head stock shaft size and thread, there are/were disc sanding attachments made for lathes that screw right on. The old ones (metal) were designed for use with disc adhesive, but there are now conversion kits to switch to hook/loop discs. You could then construct a support surface using the tool-rest base.
Even if it's not the best of lathes, I'd retain the turning capability.
- Ralph
Ralph Barker is offline
Which bit? Duplicating lathe with mounted router msn56 General Routing 5 03-04-2011 03:26 AM
Corect name router lathe tigerhellmaker General Routing 6 01-03-2010 11:47 PM
The new lathe is here and I am hooked! dustmaker Woodturning and Lathes 29 10-11-2009 10:58 PM
Router Lathe bobj3 The Bargain Bin 9 06-24-2009 04:12 AM
Central Machinery... Hamlin Starting Off 8 06-11-2006 12:10 PM
