edging - Router Forums
post #1 of 4 (permalink) Old 04-26-2006, 06:28 PM Thread Starter
Default edging
i made a plaque but i don't know how to put nice edge on it, the plaque is wavey
Codfather is offline
post #2 of 4 (permalink) Old 04-26-2006, 09:57 PM
fibertech's Avatar
First Name: Derek
Send a message via AIM to fibertech
Can you post a picture? The experts here will steer you home. -Derek
fibertech is offline
post #3 of 4 (permalink) Old 04-26-2006, 10:30 PM
Codfather
If it's real wavey use a bit that has the shank of the router bit on top if it's not to wavey use a bit that has a top bearing on it.
It will run on the side of plaque and should give you a nice edge.
This is a job for the router table.
Don't go to slow with the shank type router bit it will burn the edge.
Hope this helps
Bj
post #4 of 4 (permalink) Old 04-27-2006, 08:56 AM
If you are creating a modern looking plaque you can use an ogee, round over or chamfering bit with a bearing on the end. For an antique looking plaque use a rotary surform tool in a drill press or a simple round wood rasp or file to create uneven semicircular cuts along your edge. See example here:
http://routerforums.com/showpost.php...79&postcount=3
Let us see the finished product.
What Router Bit for Table Edging? Clem Wixted Router Bits - Types and Usage 43 10-04-2018 06:30 PM
best way to route a frame style edging? sf_basilix General Routing 6 02-11-2010 06:30 AM
Edging the table AxlMyk Project Plans and How To 21 03-30-2008 11:20 AM
Edging Codfather Table-mounted Routing 2 04-20-2006 07:58 AM
