Craftex CT146 Table Saw - Dado spec - Router Forums
post #1 of 2 (permalink) Old 03-29-2011, 04:27 PM Thread Starter
First Name: Xavier
Default Craftex CT146 Table Saw - Dado spec
Do any of you own (or have owned) a CT146 Table Saw. Am considering purchasing one but the dado capacity is important to me. I am getting conflicting info in this regard. The manual says nothing at all about dado blades. The rep tells me it can take a maximum 5/8" stacked dado if the blade stablizer (washer) is removed. That somehow sounds wrong to me only because I believe this saw is a Ridgid 3660 clone and I am pretty sure the 3660 takes wider stacks (correct me if I'm wrong). Can anyone tell me, based on experience, what the correct spec is?
Thanks,
Xavier
XavierG is offline
post #2 of 2 (permalink) Old 03-29-2011, 05:33 PM
allthunbs's Avatar
First Name: Ron
Thanks,
Xavier
Hi Xavier:
Talk to Carl in the Ottawa Store. He's usually pretty good with technical stuff like that. BTW, my Ridgid T3650 is identical and it's supposed to take a 7/8" stack. You might run it without the stiffener. You shouldn't need it. Dado sets are pretty thick and they're not usually large diameter?
Hope this helps.
Allthunbs
allthunbs is offline
New Router Table flemingj1122 Table-mounted Routing 13 05-19-2012 03:02 PM
Current iteration of Sommerfeld router table Doc Jackson Table-mounted Routing 44 07-26-2010 09:33 AM
New router, need table, building dovetail cabinets santana157 General Routing 7 02-02-2009 11:34 PM
Sold: Router Table or Table Top -Sam- Woodworking Classifieds 10 01-29-2005 09:15 PM
Dado blades and other table saw specialties Mike Tools and Woodworking 3 01-05-2005 08:07 PM
