Intricate Windings - Router Forums
post #1 of 9 (permalink) Old 06-30-2006, 01:30 AM Thread Starter
Default Intricate Windings
Ok guys im new here so this may seem like a dumb question to some but im not very router savy. Ive used one before but for simple uses. I need to cut out intricate windings on some letters and i want to be able to have a template for it so that it can be reproduced easily and fast. Ive atached a picture of an example. the problem im concerned about is the circular patern inside of the "I". I was hoping if anyone would be able to help me out with this and maybe recomend what type of bit to use. Thanx.
xone is offline
post #2 of 9 (permalink) Old 06-30-2006, 09:55 AM
xone
I would cut your template out on the jig saw/scroll saw then use the bits below with the bearing on the bits or a brass template guides.
http://www.grizzly.com/products/c1661z
http://www.grizzly.com/products/c1659
http://www.mlcswoodworking.com/shops...ttering_Anchor
http://www.mlcswoodworking.com/shops.../bt_brass.html
Hope this helps
Bj
post #3 of 9 (permalink) Old 06-30-2006, 04:48 PM Thread Starter
thanx bobj3, those look like they might work. One more question tho' do you have any links on where i can get a router crank? I want to mount the router upside down on a table and be able to raise it up and down.
xone is offline
post #4 of 9 (permalink) Old 06-30-2006, 06:25 PM
Xone
May I ask what kind of router do you have ?
But try this link, it should come back with many links.
Note *** use the key words
Router Lift in your search
http://froogle.google.com/frghp?hl=en&tab=wf&q=
Bj
Give a man a fish and he will eat for a day.
Teach a man to fish and he will eat for the rest of his life.
-- Chinese proverb --
post #5 of 9 (permalink) Old 06-30-2006, 07:43 PM Thread Starter
Well i dont have a router yet. That is why i needed to know about the lift mechanisms, so that i could buy a router that would be compatible with the lift.
xone is offline
post #6 of 9 (permalink) Old 06-30-2006, 08:11 PM
xone
They are nice to have BUT you don't need one,they are not cheap as you will soon see.
If you use a pop out base plate with the router on it or change the bit from the top of the table,it's about 150.oo add on that's a bit of a over kill item.
Take your 150.oo bucks and put it into router bits.
But that's just my 2 cents...
Bj
post #7 of 9 (permalink) Old 07-02-2006, 01:36 AM
Without any dimensions it is difficult to advise you of what to do. Also what is to be cut out the dark or light area
Tom
template tom is offline
post #8 of 9 (permalink) Old 07-02-2006, 01:39 AM Thread Starter
the dark area is to be cut out. not realy any deminsions just want to know how to replicate the swirling action easily and fast.
xone is offline
post #9 of 9 (permalink) Old 07-02-2006, 10:05 PM
Xone, provided that your dark area to be removed is 1/8" wide or larger you are best off free hand carving this with a Rotozip and Sabercut bit. Artists use the Rotozip to do intricate designs in wood. As with any tool there is a learning curve, so dont expect to get it perfect on your first try. Depending on how deep you are cutting and the scale of your carving you might consider looking at the wide range of carving tools available at Woodcraft and other retailers.
