Another strange level pix attempt - Router Forums
post #1 of 3 (permalink) Old 07-04-2006, 07:34 AM Thread Starter
Default Another strange level pix attempt
I've tried a couple times to send you fellas pictures of the "mystery" level I bought but my pix don't come through. Will try again. Here we go....
Birch is offline
post #2 of 3 (permalink) Old 07-04-2006, 10:14 AM
Birch
This may help you ▼
The administrator may allow you to use the attachment feature of this forum, which gives you the ability to attach files of certain types to your posts. This could be an image, a text document, a zip file etc. There will be a limit to the file size of any attachments you make, as the forums should not be used as an extension of your hard disk!
To attach a file to a new post, simply click the [Browse] button at the bottom of the post composition page, and locate the file that you want to attach from your local hard drive.
Only certain types of files may be attached: these are the valid file extensions for files to be attached to this forum: bmp doc gif jpe jpeg jpg pdf png psd txt zip.
After posting, the attachment will show up in the body of your message. To view the contents of the attachment (if it is not already displayed) simply click the filename link that appears next to the attachment icon
Also take a look at the link below
http://www.routerforums.com/showthread.php?t=526
Bj :
post #3 of 3 (permalink) Old 07-04-2006, 07:39 PM
Community Founder
Mark's Avatar
First Name: Mark
Birch, I've just tested the attachements and everything is working fine. Possibly you're trying to attach a file which doesn't meet the standards of this forum.
Mark,
Founder of RouterForums.com
Mark is offline
Identify Stanley level? Anniedog Tools and Woodworking 6 11-17-2010 06:41 PM
My first attempt harrysin Woodturning and Lathes 17 03-10-2008 06:55 AM
1st Attempt at a Black Finish (sample pics) Nickbee The Finishing Touch 25 01-26-2008 10:30 AM
Level Garage floor lablover Tools and Woodworking 28 07-10-2007 06:45 AM
Mystery Level Gets Worse!!! Birch Tools and Woodworking 3 06-25-2006 11:20 AM
