M12V Wrench - Router Forums
post #1 of 2 (permalink) Old 07-12-2006, 11:51 PM Thread Starter
First Name: Simon
Default M12V Wrench
Hi Everyone,
I was wondering where I can get the other wrench used to hold the shaft when loosing the collet nut. Thanks for any assistance.
shanohano is offline
post #2 of 2 (permalink) Old 07-13-2006, 07:24 AM
steveo's Avatar
First Name: Steve
Originally Posted by shanohano
Hi Everyone,
Hi, the "stamped" wrench that comes with the M12V (21 mm), and other tools, is not worth using (IMHO). Get yourself a 24 mm and a 21 mm wrench (sometimes reasonable at a swap shop etc.) Get someone to "thin" the end of the 24 mm wrench to 5 mm or less (0.2 in ) and you will be able to use both wrenches the way Bob and Rick do to change bits.
Steveo
steveo is offline
Two wrench method- one wrench router Delta6mike General Routing 68 03-26-2012 09:25 AM
Hitachi MV12 two wrench system cbsjoez1935 Table-mounted Routing 15 04-22-2007 05:51 AM
Setting the proper RPM on the Hitachi M12V jrs4464 General Routing 5 01-10-2007 09:34 PM
M12V pricing/seller dtaylor15 General Routing 1 01-27-2006 11:41 PM
M12V Second Wrench [email protected] General Routing 5 12-08-2005 04:26 AM
