spiral bits - Router Forums
post #1 of 4 (permalink) Old 07-24-2006, 01:35 PM Thread Starter
Default spiral bits
I've been trying to find a 7mm bit. Does anyone know if it excists?
dbcole is offline
post #2 of 4 (permalink) Old 07-24-2006, 02:45 PM
dbcole
I don't know of anyone that makes it in a carb.spiral bit type.
7mm = .275" ,just asking why can't you use a 1/4" and make a 2nd pass to get the size you want. ???
1/4" = .250"
http://www.cheyennesales.com/catalog...811_070_11.htm
http://www.cheyennesales.com/catalog/cmtstraightmet.htm
Hope this help
Bj
post #3 of 4 (permalink) Old 08-04-2006, 09:29 AM Thread Starter
Thanks for all your help, I needed to plunge 1/4" holes for 1/4" peg. peg to tight so went to 17/64 brad point which is .25 mm smaller than a 7mm bit. Again thanks for all your help. db cole.
dbcole is offline
post #4 of 4 (permalink) Old 09-02-2006, 10:08 AM Thread Starter
Bobj3--Thanks for the tip Bob but I have solved my Question. I bought a 17/64 brad bit from Lee Valley had to shorten it by 9/16, have it turned to 1/4 to fit router insert, then found the bit to long so had to put a 5/8 shim between router & base plate. This worked great. One thing though you have to plung quite slow or you get tearout on the top of project. Hope someone else might be able to use this info. Bye for now Doug Cole.
dbcole is offline
MLCS spiral bits rich1 General Routing 3 02-15-2008 08:09 PM
Spiral Bits RustyW Router Bits - Types and Usage 5 08-18-2007 10:47 AM
Spiral Bits fibertech General Routing 8 04-19-2006 11:06 AM
Spiral bits? archer_456 General Routing 6 04-11-2005 10:31 PM
Spiral Bits ejant General Routing 4 02-09-2005 07:15 PM
