question about 14" bandsaw - Router Forums
post #1 of 7 (permalink) Old 08-04-2011, 09:04 PM Thread Starter
barbsbus's Avatar
First Name: Barb
Default question about 14" bandsaw
We are considering buying a 14" Grizzly band saw. We owned one about 10 years ago but had to sell it before we moved. It was 3/4 hp and single speed. Grizzly still offers that same basic saw for $375. They also offer 2 saws, each are 2 speeds and each are rated at 1 hp although there is a small difference in amp rating. One is painted white ($425) one isn't ($475). Do you think a home wood shop needs 2 speeds and is the 1 hp better than the 3/4 hp. Please advise. This is for "my girly shop", I am even painting the cabinets fun colors.
I plan on resawing and making bandsaw boxes and also have a lathe and hope to use the free tree wood from the wood pile.
barbsbus is offline
post #2 of 7 (permalink) Old 08-05-2011, 12:26 AM
papawd's Avatar
First Name: warren
I was looking at them and basically I saw no difference except for the white paint, when I do pull the trigger I will go for the 1 h.p. always better to buy what Ya can than try and save a few dollars then be aggrivated later when Ya might need the extra power
papawd is offline
post #3 of 7 (permalink) Old 08-05-2011, 12:35 AM
CanuckGal's Avatar
First Name: Deb
Considering the $425 saw is identical to the $475 saw with the exception of color, I'd say save yourself the $50.00. For resawing I would choose 1 HP over 3/4. Having the option of adding a riser block is a bonus too. Down the road your "girly" shop may find good use for it. If you have 220V service in your shop that saw is going to be a serious workhorse! I would invest the extra $50 over the $375 saw and have the extra oomph just in case you need it.
I plan on upgrading my bandsaw one day, and I looked at that Grizzly model myself.
I measured, I marked, I cut.
CanuckGal is offline
post #4 of 7 (permalink) Old 08-05-2011, 12:59 AM
A caveat on riser blocks, at least on the Grizzly 0555, it eats up almost an inch of throat depth when installed.
TomE is offline
post #5 of 7 (permalink) Old 08-05-2011, 04:43 AM
xplorx4's Avatar
First Name: Jerry
1 hp, 11/2 is better yet, you'll be glad you did down the line when you add the riser block and do re-sawing.
Lamentations 3:22-23
xplorx4 is offline
post #6 of 7 (permalink) Old 08-05-2011, 01:18 PM
MikeMa's Avatar
I purchased the G0555P (the white one) earlier this year. I do not yet have the riser block for it. I will say it is a good solid saw. I run it mainly with a 1/4" timberwolf blade which makes a great cut! The saw comes with a 3/8" blade which I have never used, as based on several recommendations I received, the blade is junk.
On one of the other community sites I frequent, there are at least 3 or 4 others that have the identical saw (with the exception of the paint color), and it was based on all of their positive recommendations that made me decide to pull the trigger on the Grizzly. I have not regretted it.
MikeMa is offline
post #7 of 7 (permalink) Old 08-05-2011, 02:05 PM Thread Starter
barbsbus's Avatar
First Name: Barb
Thanks everyone for your input. Will let you know what I can talk my hubby into. I think if I make him a peach pie he will go for the very best.
barbsbus is offline
Saw B227 (AW14-M1 - Hung Li Hsing) 14" bandsaw allthunbs BusyBee Manuals 9 03-13-2019 11:41 AM
Craftsman 14" Bandsaw dhern Tools and Woodworking 40 04-21-2011 07:50 AM
14" BandSaw Advice RobW Tools and Woodworking 14 04-30-2009 08:37 PM
Bandsaw Question jarhead165 Starting Off 6 01-24-2006 07:47 PM
