Help making a domino holder - Router Forums
post #1 of 4 (permalink) Old 11-08-2011, 11:06 AM Thread Starter
First Name: Chuck
Default Help making a domino holder
Hi All,
I want to make a domino holder, that has five slots of 1/2 inc at about 50 degrees slant.
Any suggestions?
Thanks in advance
chuck 5620 is offline
post #2 of 4 (permalink) Old 11-08-2011, 11:56 AM
AxlMyk's Avatar
50º slant? That's quite a bit. I would think holding dominoes straight up would be better.
A 1/2" bit in a router table would then be an easy way to make dados in a length of stock.
AxlMyk is offline
post #3 of 4 (permalink) Old 11-08-2011, 12:03 PM
OPG3's Avatar
First Name: Otis
Chuck, In reading this I am uncertain of what "inc" means. Inch or Inclination? If it's inch, that's easily done. If it is inclination - that would most likely be a table saw cut. This is where a picture could be worth a thousand words. OPG3
OPG3 is offline
post #4 of 4 (permalink) Old 11-08-2011, 01:56 PM
RJM60's Avatar
First Name: Robert
Originally Posted by chuck 5620 View Post
Hi All,
Any suggestions?
Thanks in advance
I understand completely. There is a small router that I've seen (posted on thei forum) that has an adjustable base and would be able to cut the slots you want; however, you could also do this using a table saw. Use a dado blade, or just make lots of cuts with a regular blade, then sand the bottom.
The domino racks I've seen have grooves with about a 10° slant off perpendicular (or 80°). The 50° you specify is way too much of a slant.
“The single biggest problem in communication is the illusion that it has taken place.”
George Bernard Shaw
Robert
Redondo Beach, CA
RJM60 is offline
Bowl Making with router Mr. ED General Routing 1 01-26-2011 10:37 PM
New Member making Chairs Tracy White New Member Introductions 3 09-29-2009 02:08 AM
Making a pen - Photo shoot (Very picture intensive) Bob N Woodturning and Lathes 25 03-06-2009 02:42 PM
Making a vase part 1 chippypah Woodturning and Lathes 0 03-04-2008 03:23 AM
