Makita 3612c problem. - Router Forums
post #1 of 2 (permalink) Old 11-23-2011, 11:16 AM Thread Starter
First Name: mj
Default Makita 3612c problem.
Hi all,
I'm desperate to find an answer to this problem that's just occured.
My Makita router has just stopped working after only 5 minutes work.
Anyone have any idea?
I've changed the plug fuse and still not joy as yet.
Many thanks.
mjbiffo is offline
post #2 of 2 (permalink) Old 11-23-2011, 12:21 PM
BrianS's Avatar
First Name: Brian
Hi mj, welcome to our little corner of the 'net.
Have you cleaned your router lately? Sometimes they get plugged with sawdust, and no air can get thru for cooling purposes. There is a thermal shutdown due to heat, after a cool down period it resets itself. Try blowing it out to see if it makes a difference. If your router has seen lots of use, the brushes might be worn enough to require replacement, or a bearing might be going bad, (normally the bottom one) and siezing due to heat.
Brian
(Origin uncertain)
BrianS is offline
Makita 3612C TWheels General Routing 8 11-23-2008 07:58 PM
Makita 3612C table mounting - screw size? purplethumb Table-mounted Routing 1 11-23-2008 10:37 AM
Makita 3612c jw2170 Guide Bushings and Templates 17 11-17-2008 04:08 AM
makita 3612 / 3612C jw2170 General Routing 6 09-01-2008 06:37 AM
