How to install Butler's Tray Hinge - Router Forums
post #1 of 4 (permalink) Old 11-23-2011, 06:09 PM Thread Starter
First Name: Norberto
Default How to install Butler's Tray Hinge
Hi Every Body
I need help:
Could you explain to me how to install Butler's tray hinge.
Norberto
Norberto Carou is offline
post #2 of 4 (permalink) Old 11-23-2011, 07:05 PM
Hi Norberto
The easy way to buy the jig below or you can make your own very easy you just need a simple template..that the router bit can follow ..
You can buy just the plastic template from Rockler to fit you shop made jig for a song for the Butler hinge and the brass guide or pattern bit if you don't have one...
JIG ITŪ Mortising System - Rockler Woodworking Tools
see the MORE Info tab on the web page
Plus PDF file below
http://www.rockler.com/tech/RTD10308452AA.pdf
Note It did rework the jig to fit my needs and take on bigger hinges and use a simple fender washers for the quick adjustments of the jig,,I didn't post the Butler template but it's a easy one to make, if you want to see it just and I will post it..
Not all Butler hinges are the same size.some bigger and some smaller
++++ the templates below ▼ ▲ ▼ and the best bits to use with it..
http://www.routerforums.com/55251-post3.html
JIG ITŪ Hinge Mortising Jig
"Accurately create a variety of hinge mortises with this easy-to-use jig.
Install butt hinges of all sizes with the standard jig.
Use special inserts (sold separately) for butler and sewing machine hinges.
Or make your own insert for custom jobs.
It's simple to operate, and the durable aluminum construction will provide years of reliable help in the shop.
The system includes a custom pattern router bit, and complete instructions.
No insert is required for routing butt hinges.
Widest opening on jig is 4-1/2'' ."
Originally Posted by Norberto Carou View Post
Hi Every Body
I need help:
Norberto
post #3 of 4 (permalink) Old 09-12-2012, 05:05 PM
First Name: Robert
Default Butler Tray Hinge Install
Did you get them sorted?
I have some info
Regards
Robert Brennan
Robert Brennan is offline
post #4 of 4 (permalink) Old 11-19-2013, 06:02 PM
First Name: jack
Hi every body, I am Jack Stoneberger, here in Sharpsburg, Maryland, and I love playing with wood.
riverratjack is offline
Porter Cable 55160 Omnijig Review Echonav Tool Reviews 19 06-21-2015 03:59 AM
Bi-Fold Door Conversion Project - Need help with hinge selection TheCaptain DIY and Renovation 4 09-15-2011 06:49 PM
how do you install a butler hinge woodit Tools and Woodworking 4 03-06-2011 01:33 PM
Hinge mortising question Dalec Jigs and Fixtures 8 03-02-2009 07:17 AM
Butler Table Hinge joekuhn Jigs and Fixtures 3 10-05-2008 09:26 AM
