Midi Lathe - Router Forums
post #1 of 3 (permalink) Old 12-02-2011, 08:05 PM Thread Starter
Slapshot's Avatar
First Name: Andy
Default Midi Lathe
Lokking for a good Midi Lathe Delta, Penn State Industries, or Jet, any input?
Slapshot is offline
post #2 of 3 (permalink) Old 12-05-2011, 12:46 PM
MikeMa's Avatar
I purchased the Delta 40-460 a couple months ago and really like it. The machine is rock solid, great specs (1hp, variable speed, reversible, 12.5" swing), and can grow with you by adding the extension table. My only recommendation is to skip the stand and build your own, while making sure you can add weight to it.
MikeMa is offline
post #3 of 3 (permalink) Old 12-05-2011, 07:34 PM Thread Starter
Slapshot's Avatar
First Name: Andy
Thanks for the input Mike.
Slapshot is offline
Woodturning Lathes jph66 Woodturning and Lathes 10 09-19-2011 10:18 PM
Which bit? Duplicating lathe with mounted router msn56 General Routing 5 03-04-2011 03:26 AM
Vintage Delta Lathe MikeMa Woodturning and Lathes 2 11-09-2010 09:37 AM
Corect name router lathe tigerhellmaker General Routing 6 01-03-2010 11:47 PM
Turning to the lathe... pun intended Mike Woodturning and Lathes 25 12-30-2007 10:33 AM
