filling dovetail joints - Router Forums
post #1 of 7 (permalink) Old 12-05-2011, 01:10 AM Thread Starter
Default filling dovetail joints
Building two walnut toolboxs with cherry drawer fronts for my grandson and myself. I used through dovetail joints to build the box and I have some chips and very small gaps. I have read about using slivers, using sawdust with shellac, sawdust with hide glue. Any recommendations or other ideas. I have not started on the drawers yet, but probably will have the same kind of problems.
New to the forum, 70 years old and retired. Learned in high school to do woodworking and now that I am retired, have more time for projects. All ready built six rocking horses and five doll wardrobes for grandkids. Used walnut and oak and cherry depending on the preferences of the kids and grandkids.
Always looking for new ideas.
bullsupt is offline
post #2 of 7 (permalink) Old 12-05-2011, 05:49 AM
Welcome John.
Depending on the size of the gaps you could use wood glue & apply some to gap with your finger. Wait a few minutes till it starts to tack up & sand with orbital sander. The sand dust created should mix & fill into the area. After dust has filled maybe wait a few minutes more for glue to dry some more with dust imbedded before sanding flush.
Whittier, CA.
Have a nice & safe day!
jlord is offline
post #3 of 7 (permalink) Old 12-05-2011, 07:01 AM
Phil P's Avatar
First Name: Phil
I'm wary of using glue/sawdust to fill gaps, holes, etc as it doesn't take stain or even clear lacquer the same way as timber in my own experience. Depending on the finish required it may be best to do a trial run in a piece of scrap first
Regards
phil
Phil P is offline
post #4 of 7 (permalink) Old 12-05-2011, 08:47 AM
Hi John
Just one more way to fill the gap(s) in joints.
DoveTail TemplateMaster (4 of 4) from Stots.com - YouTube!
post #5 of 7 (permalink) Old 12-05-2011, 10:16 AM
papawd's Avatar
First Name: warren
Very nice and helpful
papawd is offline
post #6 of 7 (permalink) Old 12-05-2011, 06:54 PM
TwoSkies57's Avatar
Hey John... welcome to the community...
I've been working on several small boxes of late and one of them was a simple box joint. I ended up for reasons unknown with several very small gaps. I took the sliver route to make the repairs and it worked out beautifully. Can't even tell when looking!!
One of the things I like to do is keep all the cutoff's while working on a given project until I'm done. That way, I have matching wood. For the boxjoints I simply cut slivers from a piece the same width, glued the pieces in place and let dry. Once dry, I fitted and glued the side together. I did make sure end grain/long grain were correct. If not, it'll stand out...I can see where using a small gents saw like in the video BJ posted would work very well in many cases.
HTH.
bill
Skipper the Penguin
TwoSkies57 is offline
post #7 of 7 (permalink) Old 12-06-2011, 01:38 AM Thread Starter
Thanks gentlemen, I will try some of the ideas and see which one I can do best.
bullsupt is offline
Dovetail Spline Joints with the OP jig bobj3 Jigs and Fixtures 16 12-15-2014 03:56 PM
Box joints versus dovetail joints rstermer Tools and Woodworking 11 08-09-2009 09:38 PM
Drawer joints - Box vs. Dovetail vs. ??? ChevyNomad General Routing 2 01-14-2005 11:20 AM
dovetail spline joints reible Jigs and Fixtures 7 10-02-2004 02:50 PM
