Shop Vac dust system - Router Forums
post #1 of 3 (permalink) Old 09-11-2006, 10:46 PM Thread Starter
Default Shop Vac dust system
I have a heavy duty shop vac and use 2" PVC pipe to run on the walls to various saws and routers. Would it be to my advantage to increase the size of the pipe to 4" and still use my shop vac connection at the collection bin? I presently have a dust collection lid that I purchased from Lee Valley and it fits on a regular garbage can.
kheppner is offline
post #2 of 3 (permalink) Old 09-14-2006, 11:22 AM
You are better off staying with your 2" pipe unless you are changing over to a much larger capacity dust collector. Your shop vac does not have enough flow to draw through the 4" pipe and you will end up clogged and cussing.
post #3 of 3 (permalink) Old 09-14-2006, 04:31 PM
Hamlin's Avatar
First Name: Ken
I'm in total agreement with Mike. If you enlarge the volume of the pipe, you will need to increase the CFM of the fan used to remove the dust.
Ken
"A VETERAN"
Hamlin is offline
Big time dust problem lnagel Table-mounted Routing 5 05-18-2009 07:58 AM
Practacle Dust control for "part timers" bob oswin Tools and Woodworking 34 07-31-2008 08:26 PM
Outlook Express problems BrianS Lobby 6 01-06-2008 08:23 AM
Dust Colection for routing Dados KentWW Table-mounted Routing 3 01-10-2007 03:18 PM
Dust collection system for Router Table yhadar Lobby 2 12-31-2004 02:37 PM
