Table Saw Parallelism - Router Forums
post #1 of 2 (permalink) Old 12-12-2011, 05:12 PM Thread Starter
First Name: Marty
Default Table Saw Parallelism
I have a Shop Fox W1745 Table Saw. In moving the saw around my shop, it has gotten out of parallel. The truncheon bolts access slots are so small that you can barely get a wrench into loosen the bolts. Compounding the problem is the fact that the bolts on the front of the saw are set back about 7 in. from the cabinet. Short of getting a torch and making the access holes bigger, I don't know what to do.
martylich is offline
post #2 of 2 (permalink) Old 12-12-2011, 06:04 PM
I am not familiar with the Shop Fox but all the saws I've had made the parallel adjusting mechanism easy to get at. Have you checked your saw manual to see what it recommends?
Router Table for Incra LS Positoner completed! Michael H Table-mounted Routing 35 03-19-2015 01:40 PM
Router table build is underway - w/pics 30coupe Table-mounted Routing 83 03-17-2014 08:28 PM
Help with router and table djonesax Table-mounted Routing 31 08-27-2012 07:10 PM
Your wisdom is sought gcodom Table-mounted Routing 8 12-10-2010 08:03 AM
Router Table Help Which One! bigroccrek Table-mounted Routing 25 04-08-2008 11:57 PM
