cutters for delta/rockwell 43-120 - Router Forums
post #1 of 3 (permalink) Old 12-19-2011, 04:27 PM Thread Starter
First Name: jason
Default cutters for delta/rockwell 43-120
I bought an old delta/rockwell 43-120 wood shaper and I am not sure what kind of cutters to use. the spidle is a cone shape and has 3/4" base on it. It also has a colet nut that can hold 1/4" router bits. But I know how to use 1/4" bits is there a way to buy a new spindle to accomadate newer cutters for this wood shaper? Also does anyone know if a manuel can be bought for this machine. Wood Shapers are new to me so any advise would be appreciated.
Jason
jasonj is offline
post #2 of 3 (permalink) Old 12-19-2011, 08:07 PM
Jack Wilson's Avatar
First Name: Jack
Hi Jason, I too have one of these older, but NICE machines. I have a 1/2" spindle and use shaper cutters with a 3/4" hole, and a small T-bushing that most of them come with, you can find shaper cutters at many sites, I have used Router bits, Saw blades, CNC Router Bits, Shaper Cutters & More for 2 sets of cutters and was happy with them, you can also check out www.infinitytools.com they may be less, but they also have less of a selection. More questions? PLEASE ask, everyone here will be happy to help as much as they can!
The shaper really turns to slow for router bits, It max's out at 10,000 rpm. I have a manual I can email you or there may be one posted onsite here
You should be able to find a spindle for this unit, watch eBay for a while.
Can you post a photo of your spindle? You can remove it by removing the nut from the bottom of the spindle below the pulley. Then it should just lift out.
Jack
He is no fool who gives what he cannot keep to gain what he cannot lose
If you cannot stand behind our troops, (and I understand, no judgement here), then please stand in front of them, remember, they're willing to stand in front of you!
Jack Wilson is offline
post #3 of 3 (permalink) Old 12-19-2011, 08:42 PM
First Name: Jack
http://www.routerforums.com/delta-ma...tml#post261198
Jack
120 degree V grooving bit? patrick_g Router Bits - Types and Usage 14 04-20-2014 03:14 PM
how to setup bearing guided cutters roman ogee in r/table please matey Table-mounted Routing 5 08-04-2012 05:07 PM
Unknown Router - removing cutters? istracpsboss General Routing 12 04-10-2009 07:34 AM
making and accurate template for an oval hand mirror bob oswin Jigs and Fixtures 31 01-20-2009 08:36 PM
Birdsmouth Cutters template tom Router Bits - Types and Usage 19 09-21-2006 09:01 PM
