Better Than Draper Compound Mitre Saw? - Router Forums
post #1 of 21 (permalink) Old 12-21-2011, 04:15 AM Thread Starter
Gaia's Avatar
First Name: Peter
Default Better Than Draper Compound Mitre Saw?
Seasons greetings,
Unless I find something better quality, features and about the same price. I'm intending if poss in Xmas sales to get a Draper 52939 210 mm Sliding Compound Mitre Saw.
Do forum members have any opinions?
Cheers,
Peter.
Gaia is offline
post #2 of 21 (permalink) Old 12-21-2011, 08:29 AM
TheOakDude's Avatar
First Name: Paul
Try Makita 1216.....awesome.
The moving finger writes....and having writ moves on...nor all thy piety nor wit shall lure it back to rub out half a line.
TheOakDude is offline
post #3 of 21 (permalink) Old 12-21-2011, 11:59 AM
paduke's Avatar
I just bought triton 8 1/2" for $99.99 USD from woodcraft not sure if available in UK but its a great saw. I have a hitachi 10" that i use in the field. It has suffered abuse and remains true. the triton seems to be as well engineeered. In choosing CMS I would recommend a two tube slide action not a single. Good luck no matter the choice
paduke is offline
post #4 of 21 (permalink) Old 12-21-2011, 12:04 PM
paduke's Avatar
I just looked at the Draper It has great positive lock positions. As a Carpenter I prefer being able to feather the blade position because I have never trimmed a perfectly square corner I hope this helps you decide.
paduke is offline
post #5 of 21 (permalink) Old 12-21-2011, 03:26 PM Thread Starter
Gaia's Avatar
First Name: Peter
Thanks for the tip
Gaia is offline
post #6 of 21 (permalink) Old 12-21-2011, 03:28 PM Thread Starter
Gaia's Avatar
First Name: Peter
OK cheers.
Gaia is offline
post #7 of 21 (permalink) Old 12-21-2011, 03:37 PM
TheOakDude's Avatar
First Name: Paul
Evolution 3s very good option at that price point 99.00(Screwfix) very good with wood, also cuts aluminium and steel. Very good saw have used one for 3 years built like a tank. Cant fault it. Worth a look.
post #8 of 21 (permalink) Old 12-21-2011, 04:52 PM Thread Starter
Gaia's Avatar
First Name: Peter
Hi again thanks, I've pretty much decided to get a Makita, the LS1040 Makita Mitre Saw 260mm 1650w motor. The best price I've found for this is 140 all in, has larger saw blade and so greater depth of cut. Am also motivated by reputation, quality of the Makita name.
Thanks again for pointing me in the right direction on this one
Will also refer to Amazon.com reviews, expect they will all be postive, but..... curiosity.
I can also get other 24t, 40t Dewalt or Trend blades to put on it, for the same delivery cost. Though the cost of these makes of blades seems pricey to me, any ideas for other good quality makes, that may well be less expensive.
Cheers,
Pete.
Gaia is offline
post #9 of 21 (permalink) Old 12-21-2011, 04:56 PM Thread Starter
Gaia's Avatar
First Name: Peter
I play electric slide a bit, do you
Gaia is offline
post #10 of 21 (permalink) Old 12-21-2011, 05:10 PM
istracpsboss's Avatar
Country: Croatia
First Name: Peter
hi Peter
i went with a 10" Fox one but they seem to have gone up a lot.When I got mine it was under a hundred. You might find 210mm a tad limiting. 255mm should be attainable at a reasonable price. Actually, just had a look on eBay and UK prices seem to have risen sharply. Maybe better prices in January when they are all looking for business !
Cheers
Peter
istracpsboss is offline
A "closed-in" mitre track? matt1710 Table-mounted Routing 8 05-22-2011 07:27 AM
Mitre slot : straight or T-slot? matt1710 Table-mounted Routing 5 05-10-2011 10:55 PM
Triton 10" Compound mitre saw - $199+ship jschaben The Bargain Bin 7 09-11-2010 01:25 PM
Do you use a mitre gauge on a table? neoshed Table-mounted Routing 10 11-01-2007 09:32 PM
