Right tool for the job? - Router Forums
post #1 of 13 (permalink) Old 12-23-2011, 02:33 PM Thread Starter
Kristin D's Avatar
First Name: Kristin
Default Right tool for the job?
Have a laminated disk 9" in diameter 2.5" thick with a 1/4" thick laminate on one face I would like to cut into 8 equal 'pie shaped' parts. I do not want to drill a center hole in it to preserve the pointed ends and am wondering what tool to use, table saw, bandsaw or radial arm saw, I would use the miter saw but it maxes out at 5.25" cuts at 90 deg. Idealy I would like to use a fine tooth blade to provide a smooth finish and minimise finishing the parts, seems like the RAS or table saw would bind due to the thickness of the material if I put in a plywood blade. Band saw seems to be ideal but I would have to travel some distance to use a friends and hate to bother them on a holiday weekend but I have to get this done in time for Christmas.
Suggestions welcome, perhaps some sort of jig or fixture in a octagon shape to guide along a fence?
Kristin
Kristin D is offline
post #2 of 13 (permalink) Old 12-23-2011, 03:30 PM
kp91's Avatar
First Name: Doug
Bandsaw would be my first suggestion
Double stick tape it to a sacrificial piece with a straight edge to give you a guide for a straight cut on the table saw.
After you have a half circle, your miter saw should work
You have that beast of a scrollsaw for your avatar, a #9 blade and a lot of patience could give you good results, with a little sanding to dress the edges if you aren't perfectly straight
1 John 1:9
Fredericksburg, VA
kp91 is offline
post #3 of 13 (permalink) Old 12-23-2011, 03:43 PM
Kristin, for this project I would use my table saw with a sled. You know the cut will be exactly where the edge of the sled is. Measure the thickness of your saw blade.(Mine is 1/8") Buy a roll of automotive pin stripe tape the same width as your blade and use it to mark your layout on the piece. This way you know exactly where the cut will go with no math.
post #4 of 13 (permalink) Old 12-23-2011, 03:48 PM
Hi Kristin
Your RAS should will do the job fine ,you don't need to cut the full depth in one pass .two or 3 will do just fine..I would stick/pin nail it down to some 1/4"/? thick plywood for the RAS saw job
Just like cutting a pie but not the crust.(plywood) one side of a pentagon for the plywood base plate..cut it and then turn it and make the others cuts..
Kristin
post #5 of 13 (permalink) Old 12-23-2011, 11:35 PM
The plywood blades I am familiar with only allow about 1" depth of cut. I warped one trying to cut deeper and making multiple cuts wouldn't have helped because the blade was thicker 1" in from the edge.
I don't think you can use your miter saw as my calculations come up with about 6 3/8 at 45 deg.
post #6 of 13 (permalink) Old 12-23-2011, 11:57 PM
http://www.amazon.com/Milwaukee-48-4...702339&sr=1-38
post #7 of 13 (permalink) Old 12-24-2011, 05:44 AM Thread Starter
Kristin D's Avatar
First Name: Kristin
Excellent idea for a fixture but I am thinking with the 1/8" kerf now the parts will not fit together properly, perhaps I will have to add a 1/16" lamanate to the sides to correct this.
post #8 of 13 (permalink) Old 12-24-2011, 09:48 AM
Hi Kristin
I don't think you will need to shim up the sides, because you are cutting all the way across the cir., just like cutting a 45 deg. cut on a board or to say cutting it into two parts, the parts will fit back into place just smaller..(shorter)
post #9 of 13 (permalink) Old 12-26-2011, 09:37 AM
Honored Member
harrysin's Avatar
First Name: Harry
I've put a lot of thought into your problem Kristin and I reckon that a sharp knife will solve your "problem"!
Harry
harrysin is offline
post #10 of 13 (permalink) Old 12-26-2011, 12:26 PM
Hi Harry
" I reckon that a sharp knife will solve your "problem"! " == ????
Tool Review Guidelines ~ READ BEFORE POSTING Mark Tool Reviews 4 11-30-2011 05:21 PM
Jet Tool/ ToolSelect Review The Bench Dawg Tools and Woodworking 2 11-06-2011 09:15 AM
proper tool use locoboy Lobby 0 04-01-2009 03:45 PM
Best Tool for the Job Jtomwoods Tools and Woodworking 5 06-02-2008 02:47 PM
"Free" tool from Amazon; help me select one Ladd Table-mounted Routing 8 12-12-2007 10:54 AM
