table saw questions - Router Forums
post #1 of 13 (permalink) Old 01-04-2012, 03:30 PM Thread Starter
First Name: todd
Default table saw questions
I currently have a Ridgid TS2424-0 table saw. I am looking to get a dado blade for it. I plan on using it for basic cabinet making and misc dado's and rabbit cuts. I am not an advanced woodworker and thought that the Freud SD208 would be a good start since Rockler's currently has them on sale for $65. I would also like some advice on how and what to make an auxillary fence out of to use with the dado and is it also possible to make a dado insert for my table saw or just purchase one? Thanks.
Todd
tkinor is offline
post #2 of 13 (permalink) Old 01-04-2012, 03:51 PM
Todd
Hi Todd.
Freud dado set are pretty good. I have the 8"SD 508. For auxiliary fence to use for your table saw & dado blade for rabbits etc. get a set of Universal fence clamps. You can rip a piece of mdf & drill two holes in edge for clamps. They will clamp to your existing fence.
I make zero clearance plates out of 1/2" mdf. You can use 1/2" ply if you like. If the plate is lower than top you can use pan head screws on bottom placed where plate sits & use these to adjust the level of the plate. I insert a cut off finish nail in the far end of the plate. This keeps the plate from rising when saw is running. Don't for get to drill a finger hole so you can pull it out when changing the plate.
http://www.rockler.com/product.cfm?p...fence%20clamps
Whittier, CA.
Have a nice & safe day!
jlord is offline
post #3 of 13 (permalink) Old 01-04-2012, 04:04 PM Thread Starter
First Name: todd
I figured that would be the solution for the auxillary fence but what is the safest way to cut the "groove" for the saw blade? Should I use a 10" blade and slowly move the fence over the blade? Doesn't sound real safe to me though. Thanks again.
tkinor is offline
post #4 of 13 (permalink) Old 01-04-2012, 04:17 PM
Install your dado blade & lower it fully. Install your plate. Move your fence over plate & lock it down. This holds plate down. Don't place the fence directly over the blade or you will cut into your stock fence. Start the saw & raise the blade to desired height. The blade will cut a zero clearance as it cuts thru the plate. Hopefully not into your stock fence. You can use this same operation when raising your dado blade into the aux fence for rabbits. Just beware of where your stock fence is. Here is some Youtube video's
http://www.youtube.com/results?searc...l1384l3.8l11l0
Whittier, CA.
jlord is offline
post #5 of 13 (permalink) Old 01-04-2012, 05:11 PM
jimmomech8's Avatar
I have a Freud Dado set that I used for quite a while but never liked the bottom of the dado cut. I purchased a Onsrud 8" stack and it is by far much better than the Freud and much cheaper. You can get them off Ebay.
jimmomech8 is offline
post #6 of 13 (permalink) Old 01-04-2012, 08:41 PM
First Name: Soahn (say so-in)
all I can say is. "don't use the type that wobbles to widen the groove" I inherited one of those and tried it once. Once...
mech-e is offline
post #7 of 13 (permalink) Old 01-04-2012, 11:19 PM
You can clamp a board down across the table top over the insert instead of your fence.
post #8 of 13 (permalink) Old 01-05-2012, 12:45 AM
Which model Freud did you have?
Whittier, CA.
jlord is offline
post #9 of 13 (permalink) Old 01-09-2012, 02:41 AM
jimmomech8's Avatar
Originally Posted by jlord View Post
which model freud did you have?
sd208
post #10 of 13 (permalink) Old 01-09-2012, 11:53 PM
paduke's Avatar
I have the Freud 8" and love it. I also use a wobbler style to dado for luan plywood (under 1/4")
paduke is offline
Router Table Questions witmeken General Routing 1 12-12-2011 10:08 PM
Ryobi Intermediate table ..bushings??? rbevz Table-mounted Routing 5 02-24-2011 05:43 PM
Router table refurb- Woodpeckers Unilift rstermer Table-mounted Routing 14 11-03-2009 01:21 PM
So I am considering making my own table, a couple of questions... Cowinacape Table-mounted Routing 16 03-30-2007 11:57 AM
A few router table questions. archer_456 Table-mounted Routing 17 03-21-2005 12:30 PM
