making multiple copies - Router Forums
post #1 of 3 (permalink) Old 01-11-2012, 09:21 PM Thread Starter
First Name: Steve
Default making multiple copies
Just wondering but I make a lot of stretching boards out of Western red cedar, the boards are made for stretching animal hides for trappers. Most of the boards I make are for Marten and are 3/8" thick 3' long and 4" wide. They are tapered and rounded off at the head. Currently I am cutting these out on my bandsaw one at a time, cleaning up the cut with my belt sander, and then using my router table to round the edges. This is quite a slow process.
Is there a way I could make multiple clones of a perfect board on my router table, I just bought the Freud table and router last year and am quite new to this new power tool. I also bought a set of template guides.
welcon2 is offline
post #2 of 3 (permalink) Old 01-11-2012, 09:26 PM
You could make a master template to use as a pattern. Clamp together & use a flush trim bit to make copies of your pattern. Then use a round over bit set up in your table.
Whittier, CA.
Have a nice & safe day!
jlord is offline
post #3 of 3 (permalink) Old 01-13-2012, 09:49 PM
allthunbs's Avatar
First Name: Ron
Hi Steve:
Addenda to James comments, above.
You already have a perfect pattern. Pick one of your existing boards and use that as a template. You'll need a pattern bit with a bearing on it. Attach your "perfect pattern board" to a workpice and run the router so the bearing runs on your pattern and cut the workpiece. It will match perfectly.
A bit of sanding to clean up the edges and on to the next workpiece.
Hope this helps.
Allthunbs
allthunbs is offline
New Member making Chairs Tracy White New Member Introductions 3 09-29-2009 02:08 AM
Making a pen - Photo shoot (Very picture intensive) Bob N Woodturning and Lathes 25 03-06-2009 02:42 PM
