Cut door in Half Depth wise. - Router Forums
post #1 of 28 (permalink) Old 01-12-2012, 04:30 PM Thread Starter
First Name: aaron
Default Cut door in Half Depth wise.
Anyone know how hard this would be?
basicly i want to make sliding closet doors that match my interior doors.
I was hoping i could buy normal interior doors and cut them in half depth wise to reduce there depth (every inch matters in my small bedroom!),.
this would make 2 sliding doors out of 1 interior door. (using a sheet of ply on the back side for stability.)
just not sure how i could cut them in half.
any suggestions are welcome.
redzone is offline
post #2 of 28 (permalink) Old 01-12-2012, 04:44 PM
I think with the way doors are constructed you would just destroy the door trying to do what you want to do. By using 2 full doors your only going to loose 1-5/8" to 1-3/4" extra. Or you could build the doors like cabinet doors & they would be 3/4" thick each.
Whittier, CA.
Have a nice & safe day!
jlord is offline
post #3 of 28 (permalink) Old 01-12-2012, 06:19 PM
Contributor of the Month
OPG3's Avatar
First Name: Otis
...or have you considered "Pocket Doors" ? OPG3
OPG3 is offline
post #4 of 28 (permalink) Old 01-12-2012, 06:32 PM
Good idea but in a door opening that's already established that is major work.
Whittier, CA.
jlord is offline
post #5 of 28 (permalink) Old 01-12-2012, 07:04 PM
Maybe a bifold door in a matching style?
Whittier, CA.
jlord is offline
post #6 of 28 (permalink) Old 01-12-2012, 08:03 PM
hi
post #7 of 28 (permalink) Old 01-12-2012, 08:08 PM
Bob he wants sliding doors where one sits behind in another track to slide. He is asking about splitting the doors in half along the thickness of the door using each side of the door as the front facing out.
Whittier, CA.
jlord is offline
post #8 of 28 (permalink) Old 01-12-2012, 08:35 PM
hi
post #9 of 28 (permalink) Old 01-12-2012, 08:40 PM
Might even be able to find the bi-fold doors in a style of choice. Or make them.
Whittier, CA.
jlord is offline
post #10 of 28 (permalink) Old 01-12-2012, 08:40 PM
A flush hollow core could potentially be split, most I've seen are nothing more than stressed skin construction with little more than a 1-1/2" frame with cardboard battens within the field of the panel. Skillsaw with rip guide to slit the door frame, a handsaw could be used to finish off any blocking installed for hardware. Then gently separating the skin from the carboard battens.
Six panel (or similar) molded hardboard would be tough.... although some stressed skin elements exist, the molded decor of panels might be pressed/glued too tight together internally to split. Potential again to use hand saw if door can be initially split with skillsaw then pry apart to see if panel sections will release.
A real wood door?...... might consider just approximating existing doors using applied trims to a piece of plywood or mdf.
TomE is offline
Dovetail Depth of Cut Sherwood Portable Routing 10 11-19-2012 10:36 AM
Old Glossary Terms Mark Site Help and Suggestions 0 10-14-2008 02:30 AM
Freud 2200E -- How do I set it up for a measured depth plunge cut? Ladd General Routing 8 11-12-2007 04:23 PM
Dovetail Spacing Calculations FlyMaster Table-mounted Routing 15 05-24-2007 05:30 PM
relationship between thickness and depth of cut Bear Starting Off 2 02-11-2007 09:44 PM
