Cutting 45 - Router Forums
post #1 of 3 (permalink) Old 01-14-2012, 07:58 AM Thread Starter
Default Cutting 45
When cuttng a 45 degree cut on a table saw in order to make a box how do I stop the blade from pulling the board and thereby making the adjorned corners not fit?
windrider is offline
post #2 of 3 (permalink) Old 01-14-2012, 10:04 AM
Not sure if I understand your problem. Is your material lifting after the cut? If so use a push block that catches the edge as well as extends over the top kind of like a shoe with a heal. You can also add a feather board on the fence to keep material flat on the table. Adding one just before the blade would help too. Helps keep your material straight against then fence as it's being cut.
Whittier, CA.
Have a nice & safe day!
jlord is offline
post #3 of 3 (permalink) Old 01-14-2012, 10:20 AM
Make a jig with hold downs.
waho6o9 is offline
Cutting boards for gifts.... gad5264 Project Plans and How To 16 08-17-2016 08:35 AM
Cutting out Circles and Arcs the Easy Way learnexperience Portable Routing 1 11-26-2011 02:29 PM
New router and which starter router bits for my useage? Skyglider Router Bits - Types and Usage 11 12-08-2010 10:42 PM
Walnut/Maple Cutting Board TRN_Diesel Show N' Tell 26 12-21-2009 11:57 AM
Climbing, climb cutting TWheels Tools and Woodworking 9 08-27-2009 01:10 PM
