Am I thinking correctly?? - Router Forums
post #1 of 10 (permalink) Old 01-14-2012, 04:52 PM Thread Starter
First Name: todd
Default Am I thinking correctly??
I have a Ridgid 14" bandsaw and am tired of moving it around by dragging it on its rubber feet across my concrete floor. I am thinking about making a 2 x 4 base frame and putting 2 fixed and 2 locking casters on the bottom. Would this make it more or less stable during use? Any opinions? Thanks.
Todd
tkinor is offline
post #2 of 10 (permalink) Old 01-14-2012, 05:04 PM
OPG3's Avatar
First Name: Otis
That depends on several things, Todd. Weight of your bandsaw and type of base you choose to build. I have a table saw made by Hitachi, which has wheels that can be "down" for rolling and then "up" for sawing. Numerous commercially made units are available, but it can be easily enough made in your shop. You want 4- sturdy wheels mounted to the base via a swinging mechanism that will lower the wheels for rolling and raise the wheels upward to be non-supportive of your band saw. Good luck! OPG3
OPG3 is offline
post #3 of 10 (permalink) Old 01-14-2012, 05:11 PM
what OPG3 said, sound advice
waho6o9 is offline
post #4 of 10 (permalink) Old 01-14-2012, 05:26 PM
My band saw is on a frame with casters. I made mine from angle iron that the base of the band saw fits in. The wheels are mounted to 4 outrigger angle pieces this keeps the tool center of gravity close to the ground. I use locking casters & machines don't move while in use. One is a band saw The other is a drill press.
Name:	machine wheels 001 Large Web view.jpg
Name:	machine wheels 002 Large Web view.jpg
Whittier, CA.
Have a nice & safe day!
jlord is offline
post #5 of 10 (permalink) Old 01-15-2012, 05:21 PM
First Name: Dennis
I put my bandsaw on a wooden frame with coasters as you propose. It is very steady but I find it's a bit too high now. Not a huge problem but I would prefer the original height. The casters that drop are a good idea.
denniswoody is offline
post #6 of 10 (permalink) Old 01-15-2012, 10:20 PM
First Name: Nat
Default Band saw on casters
I have had my 12 in. delta band saw on casters for years now without any problems.
quartrsawn is offline
post #7 of 10 (permalink) Old 01-16-2012, 01:54 AM
papawd's Avatar
First Name: warren
My router table,drill press and shopvac/dust deputy are made on some type of base with locking casters as this is needed due to room in shop.....
papawd is offline
post #8 of 10 (permalink) Old 01-16-2012, 03:17 PM
Popabob's Avatar
First Name: Bob
Default Base on Wheels
Todd
Todd,
I would suggest locking wheels on all 4. I have my router table on wheels and I have locks on all. I also will upgrade to metal bracket shop wheels in the near future as the plastic ones I have are not solid enough.
Popabob
Popabob is offline
post #9 of 10 (permalink) Old 01-16-2012, 03:56 PM
Cochese's Avatar
First Name: C
The Harbor Freight mobile base gets good reviews, just supply the wood.
300 Lb. Capacity Mobile Base
A HTC base came with my jointer, it's done very well and couldn't be simpler to work with.
http://www.amazon.com/HTC-HTC2000-Un.../dp/B00002262M
The 144 Workshop - Ambitious but rubbish woodworking
Cochese is offline
post #10 of 10 (permalink) Old 01-16-2012, 08:09 PM
First Name: Drew
I have a Delta 50-941 mobile base on my drill press and it works well (the tool is just a fraction of an inch higher off the ground than it would be without the mobile base) although the lifter lever hangs out a bit in front.
http://www.amazon.com/DELTA-50-345-U.../dp/B0000223CL
Drew Eckhardt is offline
Thinking about a ShopBot kartracer63 CNC Routing 21 02-27-2012 10:08 PM
Thinking about DIY'ing a Gifkins dovtail / box joint jig.... Duane867 Jigs and Fixtures 15 11-27-2009 10:46 PM
Thinking outside the box - Moving & standing up large concrete blocks, by hand!! BigJimAK Lobby 2 10-22-2009 06:06 AM
just thinking? levon Lobby 31 05-03-2009 08:25 AM
Thinking Outloud RustyW Lobby 9 04-27-2008 11:39 PM
