Changing the motor on a drill press - Router Forums
post #1 of 6 (permalink) Old 01-18-2012, 06:26 PM Thread Starter
Jack Wilson's Avatar
First Name: Jack
Default Changing the motor on a drill press
I have a Rikon radial benchtop drill press, it has a 1/3 hp 1720 rpm motor on it and I can easily stall it out, (and have several times) . I am looking at a 1 hp 3450 rpm motor to replace it, but not sure about the speed increase, anybody know if I can reduce the rpm at the motor? At a minimum let me say that I am not a big fan of 1/3 hp motors, wish I had known how wussy it was before I bought it.
Jack
He is no fool who gives what he cannot keep to gain what he cannot lose
If you cannot stand behind our troops, (and I understand, no judgement here), then please stand in front of them, remember, they're willing to stand in front of you!
Jack Wilson is offline
post #2 of 6 (permalink) Old 01-18-2012, 07:24 PM
First Name: Jack
It would be much easier to just replace the motor with one that has the same rpm.
Otherwise, you will have to change to pulley sizes to compensate for the rpm increase.
barking spider is offline
post #3 of 6 (permalink) Old 01-18-2012, 07:50 PM Thread Starter
First Name: Jack
Ahhh yes, I thought about that, but the price is right! How is the speed determined? Is there an electrical solution, like remove this or that and the motor will slow down? (I don't mean remove the plug from the wall)! Or what about a rheostat, would that slow the motor but keep the hp?
Jack
post #4 of 6 (permalink) Old 01-18-2012, 08:37 PM
RJM60's Avatar
First Name: Robert
From you post, it's clear that both the old and new motors are induction motors. Electronic speed control for these requires a frequency control unit and, although they are less expensive now, they're still not cheap. It would be cheaper to buy the right motor.
A 1720 rpm motor has 4 poles whereas a 3450 rpm motor has 2. You cannot simply rewire anything; the construction is different.
You'll want to by a closed frame, fan cooled motor. The cheapest one I've seen is from Harbor Freight but you might be able to find something on Craig's list as well. Make sure the shaft will fit your pulley (these type/size motors always have a 5/8" shaft).
1 Horsepower Farm Duty Agricultural Motor
“The single biggest problem in communication is the illusion that it has taken place.”
George Bernard Shaw
Robert
Redondo Beach, CA
RJM60 is offline
post #5 of 6 (permalink) Old 01-18-2012, 08:56 PM
Jack, the 3450 motor might work okay if you are only drilling wood. It will likely be too fast for metal except for small bits. Too fast tends to heat the metal up and work harden it in some cases and the extreme heat takes the temper out of the drill bits. It seems contrary to logic but you can drill metal faster at slower rpm than high rpm.
post #6 of 6 (permalink) Old 01-18-2012, 09:21 PM Thread Starter
First Name: Jack
Ok, ok, I'm starting to get the point. I'll keep my eyes open for a new motor that's running @ 1720. Robert, I didn't know all that stuff about motors, but I'll keep it all in a back room in my mind!
Jack
Drill DP15501 15" Drill Press allthunbs Ridgid Manuals 2 01-18-2018 12:13 AM
Drill PRess.. help me pick please!! woodaholic Tools and Woodworking 8 09-13-2011 10:53 PM
help with drill press pls. allthunbs Tools and Woodworking 20 08-05-2010 05:24 PM
All thread for router skiis rstermer Jigs and Fixtures 99 08-09-2009 10:54 AM
Had my drill press going Glenmore Tools and Woodworking 2 08-20-2005 09:07 PM
