Shaker Cabinet Door Bits? - Router Forums
post #1 of 3 (permalink) Old 01-23-2012, 11:57 AM Thread Starter
First Name: Dave
Default Shaker Cabinet Door Bits?
I was wonder what bits are required to make shaker cabinet doors?
Are there any bits that are better then others for this? I have a router table with a Bosch 1617 EVS.
jackoman is offline
post #2 of 3 (permalink) Old 01-23-2012, 12:19 PM
Hi Dave.
You can get good bits many places. I would suggest the panel bit have a back cutter. This will eliminate a step for a bit without one. I like the Sommerfeld bits. They are a good quality set & they stay sharp. They also have a matching set for glass doors & DVD's showing everything you need to build them. Here is a couple of links.
3-Pc Shaker Set-Sommerfeld's Tools For Wood
Shaker Glass Panel Set-Sommerfeld's Tools For Wood
Marc Sommerfeld's New Expanded DVD Collection
Katana® Kitchen Door and Drawer Router Bit Set, Raised Panel Door Router Bit Sets
http://www.toolstoday.com/c-310-rais...uter-bits.aspx
Whittier, CA.
Have a nice & safe day!
jlord is offline
post #3 of 3 (permalink) Old 01-23-2012, 01:01 PM
Hi Dave
Because you are in Canada I suggest you check out the link below, I have them great set of bits and it comes with 5mm slot cutter just for plywood, as a extra item.
http://www.elitetools.ca/produit/ens...aker-prise-620
need help making shaker style cabinet doors! toro2 General Routing 2 11-21-2011 08:48 PM
Shaker cabinet doors (Newbee) williams94 Table-mounted Routing 14 08-24-2011 10:55 PM
Fastening Router Table To Cabinet DONALD Table-mounted Routing 7 04-03-2005 11:04 AM
