Buidling a desk...please need some advice - Router Forums
post #1 of 23 (permalink) Old 01-26-2012, 10:00 PM Thread Starter
First Name: Adrian
Default Buidling a desk...please need some advice
Hi there friends.
My wife wants a desk where she and my 9 yr old son can sit together and do homework while facing each other. She found a nice example of what she wants on pottery barn's website.
I need some help here on choice of woods. I can't decide on what to use....either Birch or Oak. It's going to be rather simple with some minor routering. She wants the desk top to be rather thick about 2" and 55"x 42". Any ideas and or thoughts?? I was thinking of maybe a solid wood door or simply sandwiching some 3/4" ply on top of each other to achieve the tickness.
Thanks in advance.
Cruzomatic is offline
post #2 of 23 (permalink) Old 01-26-2012, 11:28 PM
First Name: Bob
My vote would be torsion box. You can get baltic birch in 5'x5' sheets so 1 sheet would skin the whole top. 1/2" or 3/4" thick, you pick... then use whatever flat and straight hardwood core material you can find, then band the outside edges with whatever hardwood you want. You could duplicate the bookshelf boxes for the uprights or even use torsion box uprights.
anotherBob is offline
post #3 of 23 (permalink) Old 01-27-2012, 01:07 AM
wbh1963's Avatar
You can get plywood in 5/4 thicknesses. It might even be available thicker than that, not sure on that.
One layer of 5/4 and one of 3/4 is 8/4 total! It just so happens your wife is asking for exactly that thickness.... It just seems to me that one layer of 'glue' is just about half the work that two layers of glue would be..
wbh1963 is flowing with the grain in Arlington, Washington, USA
A day without curls is like a day without sunshine!
wbh1963 is offline
post #4 of 23 (permalink) Old 01-27-2012, 06:12 AM
First Name: Keith
They way I would do the top is use a good 3/4 plywood for the sub top and glue up oak boards for the main surface.The question I have is why 2" ?
Woodshaper67 is offline
post #5 of 23 (permalink) Old 01-27-2012, 08:19 AM Thread Starter
First Name: Adrian
Well, she's not exactly set on 2" thinkness for the desk top. She just likes the look of the desk in the pic I included which is 5" thick according to their website.
post #6 of 23 (permalink) Old 01-27-2012, 09:34 AM
Adrian, episodes 1205 and 1206 of The Router Workshop TV show is called the executive desk. The thick top is built with the torsion box construction mentioned by Bob. A picture is worth a thousand words. This is the easy way to build your top and make it strong but light weight.
post #7 of 23 (permalink) Old 01-27-2012, 12:46 PM Thread Starter
First Name: Adrian
Thanks Mike...I'll give that a look.
post #8 of 23 (permalink) Old 01-27-2012, 01:41 PM Thread Starter
First Name: Adrian
Just another question guys. On a 55"x42" table top what's the grid spacing I should be looking at?
post #9 of 23 (permalink) Old 01-27-2012, 02:38 PM
First Name: Jack
That top does not look anywhere near 5" thick. If it did, it would weigh a ton. Unless this desk is going to be very large, I don't see the point into going to all the trouble of making a torsion box (but that's just me).
I've made several desk tops/work counters that looked thick, but were only 3/4" plywood with a solid wood border the thickness I wanted. On a large top, I used two 3/4" pieces with solid wood border about 2" thick.
barking spider is offline
post #10 of 23 (permalink) Old 01-27-2012, 05:31 PM
Jack, the top in the photo I posted is 2" thick and uses 1/2" plywood top and bottom. It is light weight but very strong.
Adrian, the spacing is about 6" squares. I am working on getting you more information on this.
Newbie needs advice enggass General Routing 4 07-05-2010 11:08 PM
Desk and dresser Schechner Show N' Tell 16 11-12-2009 11:58 AM
Office Desk - Let's get ambitious JMalone Show N' Tell 70 10-28-2009 10:25 AM
Router buying advice welcomed. Joeofalltrades General Routing 12 07-07-2008 10:58 PM
RouterForums.com and Oak-Park.com Contest - December 2005 Mark Contests Archive 75 01-03-2006 07:28 PM
