pipe clamps - Router Forums
post #1 of 45 (permalink) Old 01-30-2012, 01:35 PM Thread Starter
mah
mah's Avatar
First Name: Matt
Default pipe clamps
I ordered some Bessy 3/4" H style pipe clamps online. I just went to the big box store to get some pipe. Bessy says that they are made for black pipe. The black pipe at the store has a hard tar like finish to it. I don't think that this would be a good thing touching my project. Is there any reason why I shouln't use galvanized pipe?
Matt
mah is offline
post #2 of 45 (permalink) Old 01-30-2012, 06:08 PM
Matt
The black pipe is better but galzanized pipe will work. I have some pipe clamps with these. I used some white thread tape so it doesn't seize up incase I wanted to change the length of the pipe for different sizes. Did you try cleaning the black pipe with some solvent?
Whittier, CA.
Have a nice & safe day!
jlord is offline
post #3 of 45 (permalink) Old 01-30-2012, 07:16 PM
dutchman 46's Avatar
First Name: Howard
I would go with the black pipe, Matt! The galavanized is slippery. and the clamp could slip under pressure. You could loose a grip, and have a glue adhession problem. Or worse yet, the clamp can move, or hit You. The black pipe can be cleaned up with solvent. I have seen it happen,where the clamp lost pressure, and liid on the ground when the Guys got bacK THE NEXT DAY!
John 3:16
dutchman 46 is offline
post #4 of 45 (permalink) Old 01-30-2012, 07:59 PM Thread Starter
mah
mah's Avatar
First Name: Matt
Thanks guys I will pick up the black pipe and some solvent.
Matt
mah is offline
post #5 of 45 (permalink) Old 01-30-2012, 11:47 PM
Matt, Rockler sells zinc plated pipe for use with clamps. They claim glue doesn't stick to it as easy. I have never tried it; I just clean up my black pipe with some solvent.
post #6 of 45 (permalink) Old 01-31-2012, 12:19 AM
MEBCWD's Avatar
Matt,
Remember there will be plenty of fumes when you use the solvent to clean the pipes.
Don't do it around open flames, this includes the pilot light in a gas water heater if there is one around. Do it with plenty of ventilation, outside would be the best location.
Let the rags sit in a open area so the solvent can evaporate before disposing of them.
Stay safe, have fun, cut some wood,
MEBCWD is offline
post #7 of 45 (permalink) Old 01-31-2012, 12:59 AM Thread Starter
mah
mah's Avatar
First Name: Matt
Thanks Mike and Mike
The rockler pipes seem expensive so I think I will go with the black pipe.
My shop is the back yard so ventilation is covered
Matt
mah is offline
post #8 of 45 (permalink) Old 01-31-2012, 05:27 AM
rrj
rrj's Avatar
First Name: Bob
Matt,
I have been using only galvanized pipe with my pony clamps for years and have no problems with slippage, my hands don't get black from the black pipe and they don't stain the wood. Everybody has their opinion on this subject but all the professionals I know prefer to use galvanized over black pipe.
rrj is offline
post #9 of 45 (permalink) Old 01-31-2012, 05:56 AM
First Name: Keith
I have used black pipe for 30 plus years.I have had galv pipe let the clamp slip.Black pipe is the way to go the blank finish is just a coating to stop it from rusting.
Woodshaper67 is offline
post #10 of 45 (permalink) Old 01-31-2012, 07:57 AM
CharleyL's Avatar
First Name: Charley
I tried galvanized pipe and had slipping problems. The black pipe works, but you have to clean the protective oil off of it before using it. I then found that applying a coat of paste wax to all of my clamp bars and the pipe parts of my pipe clamps keeps the glue from sticking to it, but doesn't cause the slipping problem that the galvanize coating does. I've been doing this for over 20 years now.
Charley
CharleyL is offline
Shining 1" steel pipe Check twice! Jigs and Fixtures 25 07-15-2008 02:57 AM
PVC Pipe Holes morbious Tools and Woodworking 3 02-15-2008 04:50 PM
Toggle Clamps (Update) Pop_pop1 Table-mounted Routing 1 08-29-2005 06:52 AM
T Track Toggle Clamps Pop_pop1 Table-mounted Routing 4 07-29-2005 02:22 AM
Pipe Clamp question ryan.s Tools and Woodworking 7 03-20-2005 03:41 PM
