DeWalt Biscuit Joiner Question? - Router Forums
post #1 of 7 (permalink) Old 02-02-2012, 09:54 AM Thread Starter
First Name: Robert
Default DeWalt Biscuit Joiner Question?
Hello all.
I posted a similar note on an older review thread and being new here I'm not sure if I should have started a new thread?
Anyways, I have a Dewalt DW682 biscuit joiner. Lately the biscuits seem loose allowing the pieces to slide around too much.
I've tightened the adjusting screws on the front of the machine all the way.
I called DeWalt CS and the lady suggested I check to see if the blade was loose.
I Removed the bottom plate and the nut holding the blade was tight. I loosened and tightened it again. The blade looked OK, no chips or nicks.
Tested the cut and it's still sloppy.
I'm using Bosch biscuits and all the settings 0, 10, 20 are loose.
Any ideas?
Lee Oskar is offline
post #2 of 7 (permalink) Old 02-02-2012, 12:46 PM
ggom20's Avatar
Country: France
First Name: Gerard
hello !
could you use a caliper and take measuraments of cut and of biscuit.
one of them is wrong , but biscuit, anyway, will grow bigger with a water-based glue...
the ones that wash with water.
regards
ggom20 is offline
post #3 of 7 (permalink) Old 02-02-2012, 01:45 PM Thread Starter
First Name: Robert
Originally Posted by ggom20 View Post
hello !
regards
Thanks for your response. I agree that one of them is wrong. I have three jars of Bosch biscuits in different sizes. I've tried a good selection from each in different cuts. All seem loose.
Do biscuits vary in size (mass) form different mfgs?
My guess is that the machine is fine and I'm doing something wrong.
post #4 of 7 (permalink) Old 02-02-2012, 02:52 PM
Do your biscuits match the size cutter you are using? There are different sizes.
http://lamello.com/en/products/wood-...zlamellen.html
http://www.mcfeelys.com/biscuit-join...FQVkhwodCyUJ2Q
Whittier, CA.
Have a nice & safe day!
jlord is offline
post #5 of 7 (permalink) Old 02-03-2012, 04:34 AM
ggom20's Avatar
Country: France
First Name: Gerard
hello!
Jlord is right there is basically two kind of cuts 4mm or 3mm in width.
If you have no calipper, use the non cutting end of some drill bits,
if a 4mm drill bit just fit in the cut you made its ok for most biscuits.
Regards
if your biscuits are loose in that 4mm cut then you probably got 3mm biscuits
ggom20 is offline
post #6 of 7 (permalink) Old 02-06-2012, 05:11 AM Thread Starter
First Name: Robert
Thumbs up
hello!
Regards
Thank you for your response. I didn't consider different width biscuits. I'll check them with a caliper.
post #7 of 7 (permalink) Old 02-06-2012, 05:23 AM
Hi Lee
" Do biscuits vary in size (mass) form different mfgs? " = Yes, they are all over the place I have many made by PC and no two are the same the norm..it comes down to what junk chip wood they have on hand to stamp them out of.
Question about new DeWalt DW 611 router LBrandt General Routing 29 09-01-2017 10:55 AM
Dewalt dw682 biscuit joiner bunny Tools and Woodworking 5 01-25-2011 09:00 AM
