Acetate spectacle frame. - Router Forums
post #1 of 5 (permalink) Old 02-14-2012, 10:12 AM Thread Starter
First Name: David
Default Acetate spectacle frame.
Hello,
I'm making an acetate spectacle frame, I'm stuck on how to put the groove inside the rim/aperture to hold the lens. Does anyone know of a solution? Would a woodworking router be the answer? This is only an interest not a commercial operation, I can't buy a spectacle making machine just to make one or two frames.
David Le Breton is offline
post #2 of 5 (permalink) Old 02-15-2012, 09:47 AM
CharleyL's Avatar
First Name: Charley
If the eyeglass frame is perfectly flat (maybe to be shaped in a later manufacturing step) you might be able to use a router with a slot cutter bit having just the right size guide bearing to get the very shallow depth of cut. You would need to mount the router in a table with a hole just large enough for the bit to clear and, using an appropriate holder for the acetate frame, guide the frame around the router bit and against the bearing guide. A very small bit in a small router would be required to do this, possibly a Dremel type tool. I have never tried to rout a slot this small. It will take some experimenting.
Charley
CharleyL is offline
post #3 of 5 (permalink) Old 02-15-2012, 10:26 AM
David, I used to work for DOC Optics Corp. in their machine repair department. Custom frame work was done with a Proxxon precision mini router. A tiny Dremel style slot cutter is used to cut a small dado in both the frame and lense and a plastic or nylon line is inserted in the dado very similar to a floating tenon. Ultra light weight fishing line works for this.
post #4 of 5 (permalink) Old 02-20-2012, 03:20 AM Thread Starter
First Name: David
Thanks Mike, that type of frame that you describe sounds interesting. Would it be what we call a Nylor Supra where one has only half a frame, the lens being held in by a nylon cord, fishing line as you say? Thanks again for your post.
Cheers,
David.
post #5 of 5 (permalink) Old 02-20-2012, 03:24 AM Thread Starter
First Name: David
Charley
Many thanks for your response to my query Charley, it's helpful. I was thinking that probably my best course of action would be a Dremel, with a bit of care I should be able to achieve what I'm aiming for, thanks again.
Cheers,
David.
How to Make a Mirror Frame learnexperience General Routing 7 11-03-2011 07:34 PM
How to Make a Picture Frame learnexperience Table-mounted Routing 10 09-24-2011 04:48 AM
How to Make a Decorative Picture Frame Using a Router learnexperience Tools and Woodworking 1 08-02-2011 11:47 PM
picture frame techniques reds_21 Tools and Woodworking 15 06-30-2009 04:43 PM
RT roller frame Hamlin Hamlin's gallery 3 12-14-2008 08:11 PM
