plastic hangers that you countersick - Router Forums
post #1 of 2 (permalink) Old 02-14-2012, 12:28 PM Thread Starter
Default plastic hangers that you countersick
Does anyone know where I can purchase the round plastic hangers that you countersick into the wood with a holesaw or bit. They are usually white plastic, can be the keyhole type or the saw tooth type. You see these holders on the calender frames from Lang/Pineridge. You just drill a circle hole and pop in the plastic circle. Makes life easy. Can anyone direct me to a supplier or website. Been looking for awhile and any of our wood/supplier do not know????? Thanks Linda
lindaway345 is offline
post #2 of 2 (permalink) Old 02-14-2012, 01:20 PM
The Warthog's Avatar
First Name: Roger
I think I know what you mean. You may want to try your local Canadian Tire, or Michael's if there is one near you, and look into picture framing supplies.
Cheers,
Roger
I'm not slow, I'm pacing myself!
Isaiah 44:13 Another shapes wood, he extends a measuring line, he outlines it with red chalk. He works it with planes and outlines it with a compass...
Usual kit: Table saw, band saw, dual base router and table, lathe, various saws, planer, sanders, and a multitude of hand tools.
The Warthog is offline
Alternative to thin plywood - thin hard plastic? bobbotron Starting Off 10 05-18-2012 11:14 AM
What type of plastic for a laminated table top? guitardemon Table-mounted Routing 10 03-19-2012 09:09 AM
Sears 17543 Plastic Sub Base Plate Problems hungerfo General Routing 8 02-28-2010 08:44 AM
What Router to buy (cutting plastic) stevegriswold General Routing 1 07-03-2005 12:56 PM
