Wood Choice - Router Forums
post #1 of 8 (permalink) Old 02-16-2012, 02:37 PM Thread Starter
First Name: Ron
Default Wood Choice
I need some opinions. I am going to build a cabinet for audio/video equipment under the flat screen TV. I have been using poplar for most of my furniture projects, including cribs and toy boxes, that were painted and it has worked out well so far. I am wondering if any of you have suggestions for better material suggestions for this project and why. It too will be spray painted and made a bit shabby so I am not concerned about color/stain problems.
Poplar is rather easy to get here and not too expensive which is relative I suppose. I can get random red oak at Menards at a relatively good price as well but there are other sources too.
rweerstra is offline
post #2 of 8 (permalink) Old 02-16-2012, 06:35 PM
Birch is also very pleasant to work with, and reasonably priced. Ash tends to be soft...easily dented. Same for Pine.
Avoid Mahogany if you want to paint; open grain is a pain.
DaninVan is offline
post #3 of 8 (permalink) Old 02-16-2012, 08:21 PM
dutchman 46's Avatar
First Name: Howard
Hello Ron! If You are happy with what Your using, and it will be painted I would go with the popular. You are used to using it, unless You are unhappy with it, I see no reason to change. The plus is that You may already have some pieces in the shop already. Have fun! I have seen Your projects, and they look great
John 3:16
dutchman 46 is offline
post #4 of 8 (permalink) Old 02-17-2012, 01:08 AM
papawd's Avatar
First Name: warren
I see no problem with Poplar, I have been using Cypress for some of My bigger projects but it is readily available here... I love the natural color of wood and hate when I need to paint it from time to time Good luck and I am looking forward to seeing Your projects
papawd is offline
post #5 of 8 (permalink) Old 02-17-2012, 06:20 AM
rrj
rrj's Avatar
First Name: Bob
Popular is the best choice for paint grade lumber
Bob
Lake Geneva, WI
rrj is offline
post #6 of 8 (permalink) Old 02-17-2012, 09:30 AM Thread Starter
First Name: Ron
Thanks for the input. Hey Howard, how about "coffee" next week?
post #7 of 8 (permalink) Old 02-17-2012, 09:57 AM
OPG3's Avatar
First Name: Otis
Ron, poplar is a nice wood choice. It has several qualities that make it a good choice. it is dimensionally stable, easily worked and takes glue or fasteners very well. Poplar takes paint quite well if it has been properly dried, but is also nice if stained. Poplar is quite economical and is available in all kinds of thicknesses, widths and lengths. All woods can twist, but poplar is less prone than many others. I have found it to be great for a lot of my prototype work because of these properties. Good luck,
OPG3
Tweak everything!
OPG3 is offline
post #8 of 8 (permalink) Old 02-17-2012, 11:59 AM
First Name: Howard
Sounds Good!
John 3:16
Wood Suggestion and Source in North Dallas area? tdsapp Wood Species 2 10-29-2009 08:38 AM
I need help to choose type of wood dane5547 Wood Species 4 07-25-2009 07:04 PM
Wood species ID bbdiamond Wood Species 5 07-06-2009 05:49 AM
Cherry and Mystery Wood CanuckGal Wood Species 5 06-04-2009 08:40 AM
What is the best wood to get a clean routered end-grain? bekandcurt Table-mounted Routing 17 07-03-2007 12:46 AM
