reeding box - Router Forums
post #1 of 3 (permalink) Old 02-20-2012, 12:01 PM Thread Starter
First Name: Don
Default reeding box
Hello
I am a volunteer at the Lowell's Boat Shop Museum in Amesbury Mass. We build small boats and other items to sell to support the museum. Presently we are building a 29 ft. rowing boat for a Boy Scout Camp in Maine. Along with the boat we have got to make twelve 12 ft oars. we have made a few samples but it has proven to be a lot of work because they are being made with all hand tools, the old method. We are looking for a better method of making these oars. We have heard of a jig called Reeding Box for making the round shaft with a router. We know it is a 3 sided box, but do not know how the oar is set up in the box to get the shaft round and tapered. Any help would be more than welcome.
Thanks Don Strople
boat shop is offline
post #2 of 3 (permalink) Old 02-20-2012, 09:09 PM
I don't know of the reference you make but the principle is simple enough. You do need the three sided trough. At each end there should be an endplate with a hole that is the same diameter as the square is across the diagonals. There should be sides across the trough that hold and keep the router centered to te trough. Then it is just a matter of running the router back and forth down the trough as you slowly spin the oar handle. If you want it tapered you make one end hole higher than the other. There will be a square end on the outer end that you can trim off. The square end on the inner end can be done by hand or you can make another plate with a hole equal to the newly turned diameter and placed before the inner squared part and then turn it down the same way as the rest.
If you want to make a handhold on the end with a raised half-round bead for the the base of the palm to rest against, you can use a plunge type rounding bit of the right radius, probably 3/16 to 1/4 " radius. Just hold (or clamp) the router in place, plunge the bit, and rotate the oar to make each side of the raised half-round bead. The handle end of the oar can also be shaped in this way with appropriate bits if you are so inclined. Hope this is clear.
post #3 of 3 (permalink) Old 02-27-2012, 04:31 PM Thread Starter
First Name: Don
Thank you for the info. I think I understand but I am sure it will come to me as soon as I put this info to use. If I have any problem I have you # Thanks again Don
My first box dkneifel Show N' Tell 19 02-08-2016 08:10 AM
Learning How to Make a Tissue Box Cover learnexperience General Routing 2 12-05-2011 05:56 PM
Another combination plane blade box hack rwyoung Show N' Tell 8 01-10-2011 08:41 PM
Beall Tilt Box Versus Wixey Angle Gauge bennybbc Tool Reviews 4 02-04-2010 12:01 PM
Scott Slinking Tools and Woodworking 3 01-21-2009 02:20 PM
