Overhead Routers - Router Forums
post #1 of 5 (permalink) Old 02-26-2012, 12:40 PM Thread Starter
First Name: Lowell
Default Overhead Routers
I am interested in a true Overhead Router. It seems to me that there would be more interest in a Router system like overhead routing than routing "BLIND". Even the overhead Pin Router Arm system still has you routing "BLIND". One Overhead Router that comes to mind was the no longer made Craftsman. I can find no information on it, but have a picture of one on the cover of a 1980s Book that I have. Does anyone know where I could find one of those, or one similar? Thanks.
Chubbo
Chubbo is offline
post #2 of 5 (permalink) Old 03-01-2012, 06:03 PM Thread Starter
First Name: Lowell
Default No interest.
I guess no one uses overhead routers today. I think that they would be very safe, and allow a craftsman using a router to work on his projects a lot easier, by seeing what he was doing, instead of working blind, but there seems to be no interest. I guess I'll have to build one and find out for myself.
Chubbo
Chubbo is offline
post #3 of 5 (permalink) Old 03-01-2012, 06:18 PM
First Name: Drew
People still use overarm routers for all sorts of things
Onsrud W 240 Overarm Router - YouTube
where the obvious drawbacks are that an overarm router is another expensive, heavy, large machine that's essentially a vertical milling machine with a faster spindle speed and no X/Y table.
Amazon.com: Grizzly G9981 5 HP Overarm Router 2 Speed, 3-Phase: Home Improvement
Drew Eckhardt is offline
post #4 of 5 (permalink) Old 03-01-2012, 06:21 PM
Hi Lowell
I made my own because I could not find one that would do what I wanted to do with it and at the right price.
Made it for peanuts.
CONVERTING AN OLD RADIAL-ARM SAW TO AN OVERHEAD PIN ROUTER..wmv - YouTube
with the "Daisy" Pin Router ▼
Pin Router Cutting Gear Teeth - YouTube
How to make gears - YouTube
Chubbo
post #5 of 5 (permalink) Old 03-01-2012, 08:40 PM
If you can find an old drill press you could use the table to mount a router on and the rack and pinion adjustment to raise and lower it..
Things You Need To Know About Woodworking Routers learnexperience General Routing 11 10-16-2011 04:55 PM
Overhead routers John Plews New Member Introductions 7 10-28-2009 11:08 AM
New Craftsman Routers foleylink General Routing 2 11-10-2007 11:48 PM
