rockwell 43=120 wood shaper - Router Forums
post #1 of 3 (permalink) Old 02-28-2012, 02:18 PM Thread Starter
First Name: frank
Default rockwell 43=120 wood shaper
I have a Rockwell wood shaper model 43-120 that I trying to wire the motor so the revers switch works my motor model is 62 145 if any one has this shaper please send me a email of the pictures of the wiring setup thanks frank
frankcrw2000 is offline
post #2 of 3 (permalink) Old 02-28-2012, 02:45 PM
HI Frank
Most are wired up the same see page 38 in the manual.
220 volt wiring
http://cdn0.grizzly.com/manuals/g1035_m.pdf
110 volt ,Page 35 in the manual below (3/4 HP)
http://cdn0.grizzly.com/manuals/g0510z_m.pdf
post #3 of 3 (permalink) Old 08-24-2013, 08:09 AM
First Name: Tony
If you still have the Rockwell siiting arouind collecting dust I'm sure you now know that most are not wired the same. Different switches wire differently, I'm having the same issue with a 2HP Reliant shaper. I have a Rockwell 43-110 which is indistinguishable from your machine and if you still need it I can send you a wiring diagram. Both machines look exactly like the Harbor Freight shaper and since they are discontinued may well be the same.
Mantwi is offline
I need help to choose type of wood dane5547 Wood Species 4 07-25-2009 07:04 PM
Router bit burning the wood!!! rovailla Router Bits - Types and Usage 7 07-18-2007 02:15 AM
Questions about wood Pallets and moisture GoonMan Tools and Woodworking 2 07-05-2005 07:11 PM
