Can I use 3/4" Plywood for Sliding Closet Doors? - Router Forums
post #1 of 7 (permalink) Old 02-29-2012, 10:19 AM Thread Starter
First Name: aaron
Default Can I use 3/4" Plywood for Sliding Closet Doors?
So im still looking into building closet doors vs buying doors.
I was considering using 3/4" mdf but figured the doors would be to heavy to hang off a sliding track(70lbs a door!)
So i then thought about the use of 3/4" plywood (pine spruce or whatever is cheapest paint grade) but im concerned that when i rip the wood to 3" widths for the frame that it might curl over time. Is this a valid concern?
The doors will be 28" x 80" per door. I would make a frame out of the 3/4" ply and leave 5 rectangles along the door face to get a look similar to this door without the raised inner sections
Then use 1/4" or other cheap ply attached from the backside of the doors to fill in the rectangles. I figure my total cost to make the doors with this method is 2- 1/4x4x8 + 1 3/4x4x8 sheets plus a gallon of paint so under 150 bucks vs buying 4 of the above doors at 56 a door. :S
Sooo.. any thoughts suggestions?? thanks all!
redzone is offline
post #2 of 7 (permalink) Old 02-29-2012, 10:50 AM
MikeMa's Avatar
Good project. Couple thing I would consider, first consider making the frames out of a solid hardwood. Closet doors tend to get banged around, and I have a feeling over time the plys in the plywood would begin splinter and separate. Also closet doors typically are in the neigborhood of 1.25"-1.5" thick. Using the 3/4" stock may make the overall door seem a bit flimsy.
Finally, pay a little more and get GOOD plywood. I have noticed that plywood stock at both Lowes and Home Depot have just about become useless for anything but home construction. Some of the sheets of plywood at my store made a pringles potato chip look flat. You may need to look around your area for a hardwood supplier that sells plywood, but they are out there.
Wood movement is always a concern (including curling/warping, cupping, etc) First, always try to start out with the flattest possible stock, and if need be let acclimate before using it. Next, good joinery will go a long way in preventing a piece from warping or cupping. Also always consider grain orientation, allowing the wood to move naturally will also help. This includes being aware of cross grain situation. This is why panels are often fit loose in doors. Finally a good finish will greatly help (put not entirely prevent) wood movement that could cause pieces to become warped or cupped.
MikeMa is offline
post #3 of 7 (permalink) Old 02-29-2012, 11:37 AM
RJM60's Avatar
First Name: Robert
If you're going to make a frame, why not just use solid 1x4 pine, or oak, or other. No ripping required and will make a better frame than plywood (which I wouldn't use).
If want a thicker door and have access to a thickness planer and jointer, you could plane down some 2x6 to 1-1/4 thick, joint the edges and route groves, mortises and tenons.
“The single biggest problem in communication is the illusion that it has taken place.”
George Bernard Shaw
Robert
Redondo Beach, CA
RJM60 is offline
post #4 of 7 (permalink) Old 02-29-2012, 12:32 PM Thread Starter
First Name: aaron
a 1"x3"x8ft piece of solid pine costs about 7 dollars here so that is extremely cost prohibitive considering i would need 3-4 pieces per door.
The local home depot has 3/4"x4'x8' pine paint grade for roughly $30, poplar for $38 or $48 for maple. 1 sheet would be enough to do all the framing. then they sell cheap 1/4" pine made for underlay for practicably nothing (maybe 20-30 dollars total to do all the doors)
so cost wise using the solid pine im at triple the price and might as well buy the premade doors($7x3.5 piecesx4 doors = $98)
I was considering buying just normal 2"x4"x8' spf or what not at $2.50 a board and sawing it down to give me the flat edges i need but im worried about how well it would take paint. Also finding ones without knots is usually hard as well. Then there's the problem of not owning a table saw, only have a circular saw and a router, so not sure how i would cut it down to the proper width.
Finish should not be much of an issue as i plan to paint the doors white so will use wood filler etc to fill in any major imperfections.
Soo back to the main question. How likely is 3/4" ply to warp? im sure if i dig through the 30 or so boards my local store has I can find 1 that's straight lol
redzone is offline
post #5 of 7 (permalink) Old 02-29-2012, 03:07 PM
RJM60's Avatar
First Name: Robert
I don't think the plywood will warp.
George Bernard Shaw
Robert
Redondo Beach, CA
RJM60 is offline
post #6 of 7 (permalink) Old 02-29-2012, 04:16 PM Thread Starter
First Name: aaron
awsome. So if im painting it should I consider buying the maple or poplar vs the pine? or does it matter?
i assume since it painted that if i need to repaint due to nicks adding a bit of filler do fill in the dent isnt a huge issue. If i was staining them then i could see a use.
redzone is offline
post #7 of 7 (permalink) Old 03-01-2012, 09:51 AM Thread Starter
First Name: aaron
one last question i swear!!
what should i prime the wood with? i want to use a waterbased product for the finish coat(as i have some) but have read i should use an oil based primer.
any recomendations on what to use?
redzone is offline
First Major Project - Custom Closet Cabinets (Phase 1 of 3) riffin-rich Show N' Tell 1 02-05-2012 03:39 PM
MDO for table top ebbonk Table-mounted Routing 1 01-04-2010 07:53 AM
Rabbeting 3/4" plywood edge WoodenShoe Table-mounted Routing 3 06-13-2006 01:15 PM
