Pittsburgh 3/4 Inch Heavy Duty Pipe Clamps - Router Forums
post #1 of 10 (permalink) Old 03-03-2012, 02:18 AM Thread Starter
Gaia's Avatar
First Name: Peter
Default Pittsburgh 3/4 Inch Heavy Duty Pipe Clamps
Are they any good?
Gaia is offline
post #2 of 10 (permalink) Old 03-03-2012, 07:48 AM
OPG3's Avatar
First Name: Otis
Peter, I am unfamiliar with the Pittsburgh clamps, but if they're the ones sold by Harbor Freight, they are probably fine for at least some of your work. Clamps and vices are such simple devices, it is kinda hard to go wrong. Pipe clamps, however; are something I personally never use - because bar clamps seem to me to be more versatile. With that being said, pipe clamps are sometimes the only practical way to "draw-together" long spans. Good luck!
OPG3
Tweak everything!
OPG3 is offline
post #3 of 10 (permalink) Old 03-03-2012, 09:14 AM
paduke's Avatar
I use HF pipe clamps. I find the 1/2" adequate. The 3/4 does grip better I built a clamping rack on shop wall and used them. I suggest buying pipe at Home Depot. Buy a 10' length and ask store people to cut it to lengths you want. NO CHARGE they will even thread an end if needed
How much pressure is needed for glue ups?
I have bar clamps for ratcheting things down if needed but the pipe clamps are adequate for gluing up
paduke is offline
post #4 of 10 (permalink) Old 03-03-2012, 09:21 AM
Some times called Pony clamps, I like the 1/2" ones the best.
Pittsburgh 2 pc 3/4" Heavy Duty Pipe Clamp Set - Nip on eBay!
Pipe Clamp - 3/4" Cast Iron Pipe Clamps,2 Piece
1/2" Pipe Clamp
Buy Jorgensen Pony Pipe Clamp 3 4 at Woodcraft
Buy Jorgensen Pony Pipe Clamp 1 2 at Woodcraft
Buy Jorgensen Clamp Pads at Woodcraft
Easy way to keep the nasty black marks off the wood and the glue off the pipe, use the plastic fluorescent tubes covers,split them with a razor blade knife and snap them in place..I have them for years.
post #5 of 10 (permalink) Old 03-03-2012, 09:31 AM
roxanne562001's Avatar
First Name: Roxanne
I have them.They seem to work pretty well for what I have used them for. Clamping wide panels for gluing.
Have a great day.
Roxanne
roxanne562001 is online now
post #6 of 10 (permalink) Old 03-03-2012, 01:02 PM Thread Starter
Gaia's Avatar
First Name: Peter
Hi,
I ordered 4 of them from States Ebay got a good price brand new unopened. Cost me $39.80 and $47.95 US Postal Service's flat rate box program.
Might take a while to get to me, I factored that in, as I don't need them right now, just this minute. Have to make the WoodSmith tenoning jig, finding the parts and converting metric and imperial is a bit hard going, but I'm getting there, also adapt to fit the Triton saw table The seller only had 4 pipe clamps, I see the actual pony ones are available at a good price too. I might get 4 of them too. Pipe clamps in the UK.I could only find the pony make in the UK and the price would have been 100 +. The Pittsburge ones I bought.No customs duty payable and only, I think it was 11 import VAT tax. So quite happy with that.
Cheers.
Peter.
Gaia is offline
post #7 of 10 (permalink) Old 03-03-2012, 01:13 PM Thread Starter
Gaia's Avatar
First Name: Peter
1/2" Pipe Clamp
Thanks for the tips
Gaia is offline
post #8 of 10 (permalink) Old 03-03-2012, 01:29 PM Thread Starter
Gaia's Avatar
First Name: Peter
Originally Posted by paduke View Post
I use HF pipe clamps. I find the 1/2" adequate. The 3/4 does grip better I built a clamping rack on shop wall and used them. I suggest buying pipe at Home Depot. Buy aThough if the pipe people will thread the pipe at nominal cost, will think about the vice again. 10' length and ask store people to cut it to lengths you want. NO CHARGE they will even thread an end if needed
In town I can get a 7 meter length of 3/4 inch gas pipe for around 40. They will cut to size for me free , Before I knew that, I got a cast iron pipe cutter, huge thing, got that at a very good price Ebay UK 59 like new, elsewhere 150 +. Though now, I understand I don't need it, It might come in handy for something else??? Or I could sell it at a profit.
I bought a threading die set and will need to get a pipe vice to use it. Though if the pipe people will thread the pipe at nominal cost, will think about the vice again.
I was advised to have 1 metre and half meter lengths of pipe cut for using on making up my exterior and interior doors.
Thanks.
Gaia is offline
post #9 of 10 (permalink) Old 03-03-2012, 01:33 PM Thread Starter
Gaia's Avatar
First Name: Peter
Have a great day.
Roxanne
OK thanks.
Gaia is offline
post #10 of 10 (permalink) Old 03-04-2012, 04:01 AM Thread Starter
Gaia's Avatar
First Name: Peter
Think would be an idea to get 2 x 2.25 meter lengths of pipes for clamping doors.To span the top and bottom rails.( top to bottom of door ) Also couple of 1.25 meter to span the rails, ( width ways ) Just to be sure will have to have a look at book again to see how he clamps up the doors.
Gaia is offline
Availibility Of 3/4 Inch Pipe Clamps In The UK Gaia Tools and Woodworking 0 02-28-2012 04:55 AM
pipe clamps mah Tools and Woodworking 44 02-17-2012 08:08 AM
Roundover of 3/4 inch thick table top edge Joesf Router Bits - Types and Usage 10 12-23-2010 10:04 AM
Heavy duty foot stool vikingcraftsman Show N' Tell 8 08-31-2009 12:45 PM
PVC Pipe Holes morbious Tools and Woodworking 3 02-15-2008 04:50 PM
