Non conventional tools. - Router Forums
post #1 of 14 (permalink) Old 03-03-2012, 11:07 AM Thread Starter
papasombre's Avatar
Country: Venezuela
First Name: Alexis
Default Non conventional tools.
Hello!!
I wanted to build a table for a new computer but I am not in my garage to do that, so I decided to use dowel joints for this purposes. Without the right tools, I made some of them to reach my goal.
The table isn't finished yet but, in the pictures you can see my non conventional tools.
Name:	1 Marking tool.JPG
Name:	2 Drawing the line.JPG
Name:	3 Aluminium rivets.JPG
Name:	4 Removing the stems.JPG
Name:	5 Using as dowel centers.JPG
Name:	6 Dowel centers.JPG
Name:	7 My clamps tools.JPG
Name:	8 Using my clamp.JPG
Name:	9 Using my clamps.JPG
Name:	10 Clamping the frames' legs.JPG
Name:	11 Anoter view.JPG
Name:	12 Putting all together.JPG
We, woodworkers are everywhere!!!
papasombre is offline
post #2 of 14 (permalink) Old 03-03-2012, 05:08 PM
OPG3's Avatar
First Name: Otis
Alexis, it took me a couple of views to understand what you have done here. If I've guessed right, you've made 3- clamps; each using a pair all-thread rods and passing through a pair of identically drilled boards. Tightening the nuts retracts the rods into their respective load spreaders (boards) to provide a clamping action. This is a clever adaptation to produce a purpose-built clamp. I use a lot of things similar to this in my work and often use "pass-through" knobs instead of nuts - in this way wrenches become unnecessary. Also, I have a set of wrenches which are driven by ratchets that allow a rod to pass-thru, they are perfect for use in all-thread rod situations. They're made by Gear-Wrench.
OPG3
Tweak everything!
OPG3 is offline
post #3 of 14 (permalink) Old 03-03-2012, 07:16 PM
Also the "dowel jig".........thinking outside the box.....great
Sydney, Australia
jw2170 is offline
post #4 of 14 (permalink) Old 03-03-2012, 07:43 PM
Hi
I like it, using what you have at hand ,a small size Rope also works well with a stick that you can wind up and lock it in place.
Originally Posted by papasombre View Post
Hello!!
post #5 of 14 (permalink) Old 03-03-2012, 07:45 PM Thread Starter
papasombre's Avatar
Country: Venezuela
First Name: Alexis
Hi, Otis.
You are right, my friend. I forgot to include a short description in each picture. As I wrote, I'm not in my garage where I have all the necessary tools to do this job, so I tried some tricky ways to accomplish it.
First, (pictures 1 and 2) I made a marking tool using a C clamp, a nail and two scrap pieces to draw the line to place the dowels.
Secondly, I removed the stems from the aluminium rivets and replaced them for nails to use the rivets as a dowels centers. (pictures 3 to 6)
Finally, to put all the pieces together, I used threaded bars as clamping tools. At home I use wooden knobs, copied from somebody in this forum, to delete the hex wrenches.
Secondly, I removed the stems from the aluminium rivets and replaced them for nails to use the rivets as a dowel centers. (pictures 3 to 6)
Finally, to put all the pieces together, I used threades bars as clampling tools. At home I use wooden knobs, copied from somebody in this forum, to delete the hex wrenches.
post #6 of 14 (permalink) Old 03-03-2012, 07:49 PM Thread Starter
papasombre's Avatar
Country: Venezuela
First Name: Alexis
Hi, James.
Thank you for your comments. I am sure you will do it better.
Best regards.
post #7 of 14 (permalink) Old 03-03-2012, 08:15 PM
MEBCWD's Avatar
Hi Alexis,
Necessity Is The Mother Of Invention!
You needed tools and you invented tools with your imagination and the resources on hand.
That is why we have most of the things that the human race has today ..... LIKE ROUTERS!
Good job!
MEBCWD is online now
post #8 of 14 (permalink) Old 03-05-2012, 12:42 AM Thread Starter
papasombre's Avatar
Country: Venezuela
First Name: Alexis
I forgot to metion another non-conventional tool. May be all of you have one of them. You can't drive a nail, cut a piece of wood or, even put it the tool box. Nevertheless, it has become a dependable thing: a camera!!!
post #9 of 14 (permalink) Old 03-05-2012, 12:46 AM Thread Starter
papasombre's Avatar
Country: Venezuela
First Name: Alexis
Hi
Hi, Bobj3.
Thanks a lot for your comment.
I copied the wooden knobs from a post that you wrote in this forum. Soon I'll show something I'm preparing, inspired in another one.
Best regards.
post #10 of 14 (permalink) Old 03-05-2012, 12:06 PM
The Warthog's Avatar
First Name: Roger
You're a clever man, Alexis. I really liked your dowel centering rig. I never would have thought to use pop rivets.
Cheers,
Roger
I'm not slow, I'm pacing myself!
Isaiah 44:13 Another shapes wood, he extends a measuring line, he outlines it with red chalk. He works it with planes and outlines it with a compass...
Usual kit: Table saw, band saw, dual base router and table, lathe, various saws, planer, sanders, and a multitude of hand tools.
The Warthog is offline
Quality vs Cheap tools Jennabutala Tools and Woodworking 37 08-15-2016 06:58 AM
help me set small shop, tools, layout ect... Mimielam Starting Off 24 08-08-2009 01:47 PM
