12-inch Double Bevel Sliding Compound Miter Saw - Router Forums
post #1 of 12 (permalink) Old 03-03-2012, 06:14 PM Thread Starter
Thumbs up 12-inch Double Bevel Sliding Compound Miter Saw
I am renovating an older home in Baltimore, and there is a ton of moldings of all types and I am researching for the purchase of the subject saw. I am studying to determine the parameters I need to consider. I need to be able to compare cost vs performance. Performance of the machine, I guess I should say accuracy is my biggest concern. This saw will be getting a lot of work. Any ideas would be appreciated.
PEERLESS is offline
post #2 of 12 (permalink) Old 03-03-2012, 07:43 PM
Welcome to the router forum.
Thank you for joining us.
Sydney, Australia
jw2170 is offline
post #3 of 12 (permalink) Old 03-04-2012, 06:49 AM
First Name: Keith
You will get all kinds of different opinions here is mine. After 30 plus years Makita is my saw hands done. We have use different brands though they are good saws.Makita has proved itself to us we've used them from framing houses to trim work like you are doing and when I say we (i have had some helpers that are rough on tools).If I had a second choice it would be Dewalt.When you finally buy one just remember the old saying you get what you pay for.
Woodshaper67 is offline
post #4 of 12 (permalink) Old 03-04-2012, 07:04 AM
Big Steve's Avatar
First Name: Steve
I have a 10" Makita and think it is great. For me a 12" would be overkill.
Steve
Richmond, Virginia
Big Steve is offline
post #5 of 12 (permalink) Old 03-04-2012, 09:30 AM
TheOakDude's Avatar
First Name: Paul
New Makita 1216L - awesome
or new De Walt 780
both are genuine article, very durable and as accurate as it gets.
The moving finger writes....and having writ moves on...nor all thy piety nor wit shall lure it back to rub out half a line.
TheOakDude is offline
post #6 of 12 (permalink) Old 03-04-2012, 10:43 AM
OPG3's Avatar
First Name: Otis
Peerless, I know you asked about 12" saws, but I've got a big AMEN on those that mentioned Makita Saws. I have a Makita LS1013 Sliding Compound Miter Saw. I could not be more pleased with a saw of this function. I've used numerous brands of SCMS's and can tell you that none of them compare. I looked at everything including handle cantilever, footprint, ease of adjustability, bevel capabilities, ease of relocation, etc. I even looked-at the 12" Makita and there was very little difference in them, but I am glad I made this decision. It is very easy to make all types of cuts on it, and I have numerous Makita-made accessory parts that enhance it even further! It is also a very comfortable saw to operate. I no longer need a radial arm saw and I even have 4- locations in my shop where workbenches have hole patterns to support this saw. I have noticed its dust collection bag is very effective, and the dust that doesn't get caught in the bag is easily reached with minimal effort. I have right and left handed workers in my shop and everyone prefers this saw to any others (there are some saws out there that are decidedly right handed or left handed). You do not want your workers to be using something that is an uncomfortable fit - this compromises safety! BE SMART & BE SAFE!
OPG3
Tweak everything!
OPG3 is offline
post #7 of 12 (permalink) Old 03-04-2012, 03:37 PM
BigJimAK's Avatar
I have and love the Bosch Glide 12" "hinged slider" BUT, if you're talking price/performance based solely upon cutting molding you can save a lot of money (and certainly accuracy / $-spent) buying a non-slider.
No matter how good it is, a slider is going to add cost and some small amount of wiggle to the blade that wouldn't be there if the same unit were a double-bevel chop saw only.
It'd take pretty huge molding to require the depth of cut a slide provides.
Jim
BigJimAK is offline
post #8 of 12 (permalink) Old 03-04-2012, 04:21 PM
If you need real accuracy you may also want to install saw stiffener washers on the blade. Even Forrest recommends using them and their blades are supposed to be the best.
I was having trouble once trying to get picture frame corners fit tight using a 10" Makita chop saw. The blade stiffeners solved the problem.
post #9 of 12 (permalink) Old 03-04-2012, 07:29 PM
I'd figure the capacities of intended work to be done and base the size of the saw as a starting point.
I've used the Makita 1013 (10" dc slider), DeWalt 716 (12" dc miter) and Festool Kapex(10" dc slider) as primary trim saws (use a couple more DeWalts for "rough" work)
The DeWalt handled all that the other two can except width of cut, mostly need width of cut for stairs, shelving and the like. No "dado" either with non slider.
The Makita was the old one and has served well but does not have the verticle cut capacity of the DeWalt, nor does the Kapex. Verticle cut of the Dewalt is very handy if taller baseboards and larger crowns(nested cuts) are needed. There can be, however, more inherent runout with a 12" blade.
I've recently sold the Makita and DeWalt to "offset" the Kapex. Features, accuracy, dust control and compactness in size and weight helped with the decision. I earn with it so buying for hobby or one time house reno might not merit consideration for budget. Need to bevel cut 1 x 6 whereas the Dewalt does miter cut of same. I expect this one to be the last I'll need.
Any bevel cut is much "nicer" to do with a slider compared to the plunge action of the DeWalt.
Accuracy for 99.9% of all trim jobs I've encountered is just fine with any of these saws. Verify the set of any new saw, make adjustments if needed and maintain the set over the life of the machine. Dead nut accuracy of the machine doesn't come into play very much when working trim on houses, that square cut just gives you a reference to show how outta square the house is.
Decent blades came with Makita (tenyru) and Kapex.... the stock Dewalt blade was adequate enough to suffice until better found.
Bosch, Milwaukee, Hitachi etc. all appear to be fine saws but have not had the occasion to use.
A 12" dc slider would certainly cover all of the above and if I had to pick just one saw it would probably be one of this size and that Bosch glider would be one that I'd look at real close.
Last edited by TomE; 03-04-2012 at 07:32 PM. Reason: removed link put in by some vendor software.
TomE is offline
post #10 of 12 (permalink) Old 03-04-2012, 08:14 PM
papawd's Avatar
First Name: warren
I have had 2 Craftsman (7 1/2" & 10") also 2 Dewalts one sliding and one non sliding, have sold them all when I bought Hitachi 12"sliding double compound.... I like this saw the best of all with the Dewalt coming in 2nd....I bought the Hitachi my 2nd choice when I was looking for a new saw)when after driving 60 miles to buy a Makita that was supposed to be held for me and was sold by one of the other salesman in the store , if the Makita had been available maybe I would say it is the best so far ....
papawd is offline
Saw C10FSH sliding compound miter saw kp91 Hitachi Manuals 6 03-28-2011 08:08 AM
looking for new 10" sliding compound miter saw krh109 Tools and Woodworking 4 12-19-2010 05:06 PM
sliding compound miter saw Texukdoc New Member Introductions 7 06-27-2010 11:28 PM
Bosch 5412L 12" Dual Compound Sliding Miter Saw and T4B Folding Stand Combo CanuckGal Tool Reviews 8 07-24-2009 01:19 PM
