Inlay - Router Forums
post #1 of 9 (permalink) Old 03-05-2012, 03:04 PM Thread Starter
First Name: Rex
Default Inlay
I have a 4000 Dremel and a Stewart McDonald Precision Router Base and I want to use it to make inlays. Are there bushings and bits that will work to make the inlay and the recess for the inlay?
Celeste
Celeste is offline
post #2 of 9 (permalink) Old 03-05-2012, 09:30 PM
bcfunburst's Avatar
First Name: Reg
Default Dremel Router Bits
Celeste
Dremel does have their own line of router bits advertised in their 2011-2012 catalogue. I am not familier with all their accesseries, however they are showing what they call a "Trio Tool" with accessories, and different 4 sets of router bits. I did not see any bushings in the catalogue. With a Dremel, you might try "freehand routing" for inlay. There are quite a few videos about it on youtube.
The Dremel Catalogue gives a USA phone no. 1 (800) 437-3635 and a number for Canada 1 (888) 285-3476.
Hope that's a help to you.
"Even bad decisions make good stories"
<bcfunburst>
bcfunburst is offline
post #3 of 9 (permalink) Old 03-05-2012, 10:07 PM
HI Rex
No big deal you can made your own base plate to take on the brass inlay kit they are made to work with the the 1/8" router bit..so it's a great way to use your Dremel.
The one below is for 1/4" shank router but the 1/8" bit that comes with the Dremel will work just fine..the key is the brass guide and offset ring..
Solid Brass Router Inlay Kit
http://www.stewmac.com/shop/Tools/Sp...ctures#details
http://www.youtube.com/watch?v=6vRh6...ayer_embedded#!
http://www.youtube.com/watch?v=6r7xt...endscreen&NR=1
Celeste
post #4 of 9 (permalink) Old 03-05-2012, 10:31 PM
MEBCWD's Avatar
rex
Here is a link to the Milescraft plunge base for rotary tools. It will take the Turnlock bushings and the Turnlock set has an adapter for Porter Cable type bushings.
Amazon.com: Milescraft 1000 Plunger turns your Rotary Tool into a plunge router: Home Improvement
Amazon.com: Milescraft 1217 TurnLock Bushing Set Guide Bushings for Routers: Home Improvement
Hope this helps,
MEBCWD is online now
post #5 of 9 (permalink) Old 03-05-2012, 10:43 PM
Hi
MC 1000
Just a add on note, I have one and I would rate it at 1 1/2 stars out of 5 stars and I'm a big fan of most the Milescraft stuff.
Originally Posted by MEBCWD View Post
rex
Hope this helps,
post #6 of 9 (permalink) Old 03-06-2012, 05:27 AM
Welcome to the forum, Rex.
Sydney, Australia
jw2170 is offline
post #7 of 9 (permalink) Old 03-14-2012, 10:53 AM Thread Starter
First Name: Rex
Thanks for the replies to my thread. I still have the problem of doing inlays that are small.
I want to make inlays of card suits spades, hearts, clubs and diamonds about 2" in height. This involves very tight cuts which I have done freehand with a 1/16" Dremel router bit. I would like to make a template and use the Dremel or Porter Cable/plunger to do this. Your help would be appreciated
Rex
Celeste is offline
post #8 of 9 (permalink) Old 03-14-2012, 11:14 AM
Ken Bee's Avatar
First Name: Ken
Rex
If you have a trim router get a 1/4 to 1/8 collet.
My Dremel Tool has a plunge base with a guide bushing that can be used to do inlays.
When something is advertised as being foolproof there is always a better class of fool that comes along to prove them wrong.
Ken Bee is offline
post #9 of 9 (permalink) Old 03-19-2012, 10:40 AM Thread Starter
First Name: Rex
Thank you Ken Bee for your help. I have finally purchased a Dremel plunge router base. It appears that this will do the work for me short of free hand.
Celeste is offline
Inlay tip bobj3 Guide Bushings and Templates 7 12-11-2011 01:27 PM
Making an Inlay and Inset Drawer Pull learnexperience General Routing 0 10-31-2011 06:48 AM
Inlay bushing kit questions Jray Guide Bushings and Templates 6 05-17-2009 03:11 PM
Inlay and wood movement verteramofurniture Guide Bushings and Templates 3 02-16-2009 02:45 PM
Inlay Chart/Update bobj3 Guide Bushings and Templates 3 12-19-2008 08:59 AM
