New Guy - ambitious project (for me) ahead - Router Forums
post #1 of 7 (permalink) Old 03-07-2012, 12:26 PM Thread Starter
GulfcoastGuy's Avatar
First Name: Patrick
Default New Guy - ambitious project (for me) ahead
Hi, New here. I've got sort of an ambitious project that is to be a present for my wife. A Backgammon board with case and drawers.
What I have:
Bosch 1617 with both bases.
A marginal FOLDING Wolfcraft router table.
1 cheap wood working bench from Ace Hardware
1 large home built assembly/workbench
1 bench drill press - Craftsman
1 6" bench belt/disk sander
circular saw
jig saw
palm sander
What I don't and won't have (any time soon)
Table saw
Jointer
Planner
....any other larger shop tools
I've been lurking for a while and this looks like the place for the help I'm sure I'll need.
Is there any special area for project journals?
GCG
GulfcoastGuy is offline
post #2 of 7 (permalink) Old 03-07-2012, 08:08 PM
What I have:
circular saw
jig saw
palm sander
Table saw
Jointer
Planner
GCG
Welcome to the forum.
I believe if you take your time and follow the plans carefully. you may have all the tools that you require. You will have to order your timber for a reputable supplier already planned to thickness.
I would add a small hand saw.
What type of joints are you using for the case and drawers? This could add to your required tools list.
Sydney, Australia
jw2170 is offline
post #3 of 7 (permalink) Old 03-07-2012, 08:34 PM
MEBCWD's Avatar
Welcome to the Router Forums.
You could probably post under "Project Plans and How To" or "Show N' Tell" as you go so people can give you ideas on how you can accomplish certain tasks with the tools you have available to you. Maybe Someone can keep you from making a mistake so you won't have to rebuild anything.
Good luck on your project.
Work safe, Have fum, Cut some wood,
MEBCWD is offline
post #4 of 7 (permalink) Old 03-08-2012, 11:53 AM Thread Starter
First Name: Patrick
For the most part I'll be using 1x stained poplar from one of the monster warehouse stores and hope I can get by without having to plane for the case. The board will be another matter. I'll need re-saw the 1x to 5/16(x2) Got an idea for a jig to use with my circular saw ripping jig for that, and hope to work out something on the router table to pass for a plane job down to 1/4.
Already on the list.
Plan to miter the box and am looking at the MLCS Lock Miter Bit for that. Maybe the Drawer Lock bit for the drawers.
As of now the board will be 17"x17" with points 6.75" long and 1-5/16 wide at the base to allow for 1-1/4" checkers.
GCG
post #5 of 7 (permalink) Old 03-09-2012, 03:16 AM
Big Steve's Avatar
First Name: Steve
I have never tried this but have read that sometimes a local cabinet shop will plane lumber for you for a price.
Steve
Richmond, Virginia
Big Steve is offline
post #6 of 7 (permalink) Old 03-09-2012, 07:37 AM Thread Starter
First Name: Patrick
Might look into that if my jig doesn't work. I'm looking at it as kind of a challenge to do as much as I can with what I've got. I've almost got the re-saw jig done in Google Sketchup and as soon as I have enough posts in I'll post it for critique.
post #7 of 7 (permalink) Old 03-09-2012, 03:18 PM
"I'm looking at it as kind of a challenge to do as much as I can with what I've got."
As in Life itself, GcG.
DaninVan is offline
Forum Suggestion Thread Mark Site Help and Suggestions 131 02-08-2015 09:33 AM
