24" 40-110 Delta Scroll Saw Part Needed - Router Forums
post #1 of 9 (permalink) Old 03-10-2012, 08:13 PM Thread Starter
First Name: Brian
Default 24" 40-110 Delta Scroll Saw Part Needed
Hello,
I am a "newbie" to this forum. I own a 24inch Delta 40-110 scroll saw about 50 years old. My kids and I used it for many years and created a ton of memories with it. Unfortunately, we overtightened the set screw on the lower chuck and broke it. I have been hunting for a replacement chuck (the part that grips the lower end of the saw blade) for some time with no luck. The saw is a Delta Homecrft which appears to have been manufactured in Milwaukee. Does anyone have a good idea as to where I can buy a replacement chuck for it? Thanks. Brian
gr8inblack is offline
post #2 of 9 (permalink) Old 03-10-2012, 08:51 PM
HI Brian
You may want to drop a email to the seller on eBay looks like he is into Delta and other scroll saws big time with luck he just may have it or may know where you can get one.
HOMECRAFT/DELTA 40-110 16" Scroll Saw Parts Manual | eBay
DELTA 6 Short Bed Jointer 37-205 37-207 Part Manual items in OZ Metal and Wood Machine Manuals store on eBay!
Originally Posted by gr8inblack View Post
Hello,
post #3 of 9 (permalink) Old 03-10-2012, 08:59 PM Thread Starter
First Name: Brian
Default Thanks for the E-Bay tip
Thanks for the E-Bat tip. I will give it a try. It seems like a chuck should be a common item to me, but this one resembles the old needle in a haystack-hard to find.
Brian
post #4 of 9 (permalink) Old 03-11-2012, 10:29 AM
CharleyL's Avatar
First Name: Charley
You might also check the VintageMachinery.org | Welcome website. If all else fails you might be able to get a local machine shop to repair or make a replacement part for you. This last option is usually the most expensive way to go, so use it as such, but get a quote from them before you let them do it. It may turn out to be cheaper to just buy a new saw.
Charley
CharleyL is offline
post #5 of 9 (permalink) Old 03-12-2012, 12:38 PM Thread Starter
First Name: Brian
Thanks for the tip on the vintage machinery site and the machine shop. I will try vintage macinery first. I agree that the machine shop option may be cost prohibitive, but that may be my only option-if I can't locate this part elsewhere. Brian
post #6 of 9 (permalink) Old 11-02-2013, 12:46 PM
First Name: Jack
See ereplacementparts.com delta
Jaccok is offline
post #7 of 9 (permalink) Old 11-02-2013, 05:50 PM
MAFoElffen's Avatar
The lower chuck is just stripped right? (Meaning not broken into pieces...)
If there is enough meat there, what about a heli-coil insert of the original size?
Also if there is enough meat there, you could always tap to the next size thicker. Not much difference in thickness between #6 and #8 machine screws.
MAFoElffen is offline
post #8 of 9 (permalink) Old 11-02-2013, 06:33 PM
First Name: Duane
Mike, this is a year and a half old thread, the OP hasn't been back. Probably a minor mod to just put a different blade holder on it, I'd think.
Dmeadows is offline
post #9 of 9 (permalink) Old 11-02-2013, 08:15 PM
MAFoElffen's Avatar
I hate when than happens... LOL!
315.17492 part needed mike Shove Tools and Woodworking 3 12-07-2011 11:22 AM
Delta Scroll Saw 40-601 R. Scott New Member Introductions 5 07-18-2011 10:03 AM
Delta Rockwell Scroll saw 40 110 Photos Altman Lobby 7 03-07-2011 01:49 PM
Delta Rockwell scroll saw 1956 HELP!! Altman Lobby 4 03-03-2011 07:18 PM
Sold: NOW SOLD - Delta SS 350 Scroll Saw & Stand challagan Woodworking Classifieds 4 07-25-2007 05:12 PM
