Pull saws - Router Forums
 3Likes
post #1 of 15 (permalink) Old 03-20-2012, 07:49 PM Thread Starter
Marco's Avatar
Default Pull saws
Looking for a good pull saw and am asking how easy it is to cut hardwood with one.
I purposely made some extremely proud dovetails and had planned to use a pull saw to trim the tails before fine sanding. Locally a pull saw was unavailable so got this Lowes.com Error 500 - We are having a problem with our server and the Kobalt Back saw didn't do what I wanted so am looking at this Vaughan-Bushnell BS240P Pull Stroke Handsaw: Amazon.com: Home Improvement a Vaughan-Bushnell BS240P Pull Stroke Handsaw.
...... So am I on the right track?
[B“It’s not a mistake, it’s a design feature”][/B]
Marco is online now
post #2 of 15 (permalink) Old 03-20-2012, 09:10 PM
Hi Jim - I've got this thing from Home Depot
4-3/4 in. Flush Cut Pull Saw-20-331 at The Home Depot saw&storeId=10051
I was really surprised with how well it does. I don't do hand dovetails but this thing got right with it with some oak dowels I needed trimmed.
John Schaben
jschaben is offline
post #3 of 15 (permalink) Old 03-20-2012, 11:08 PM
Shark Corp Pull Stroke Handsaw | eBay
http://i.ebayimg.com/t/Shark-Corp-Pull-Stroke-Handsaw-/00/s/NjAwWDYwMA==/$(KGrHqR,!g4E8rVqQ7,lBP(jfWMDig~~60_3.GIF
Shark brand works well also
It'll cut right through anything. One side is for ripping, the other is for crosscutting. Sometimes both sides are for crosscutting.
You'll dig it.
waho6o9 is offline
post #4 of 15 (permalink) Old 03-21-2012, 07:45 PM Thread Starter
Marco's Avatar
Thanks guys. Yes I'm just wanting to make flush cuts to trim off any excess. It's hard to believe what the stores around here do not carry.
Marco is online now
post #5 of 15 (permalink) Old 03-22-2012, 09:00 AM
CharleyL's Avatar
First Name: Charley
Jim,
Using a hand saw to flush cut off the protrusions from your dovetail joint can be difficult because any set in the saw teeth will cause scratches in the side of your work. If you want to use a hand saw for this you will need to find a "flush cut" saw which has no set in the teeth. See the attached link for an example of one of these saws (although they are available from other sources).
Flush Cutting Trim Saw - Rockler Woodworking Tools
When I want to trim a dovetail or box joint flush with the box I usually mount a flush cutting bit in my router table and then set the bit high enough so that the end bearing of the bit rides against the side of my box. I then carefully rout the protrusions flush with the side of the box. If you do it this way, be sure to use a backer board to keep the end of the cut from chipping out.
Charley
CharleyL is offline
post #6 of 15 (permalink) Old 03-22-2012, 03:17 PM
TwoSkies57's Avatar
Hey Jim...
you can't be a good flush cut saw!!! Prices will vary greatly, more often than not due to the steel used and/or the mfg. I've found that the big box saws and even those from places like woodcraft/rockler serve the purpose quite well and not for alot of money. I do have a Bridge City Tool Works saw that I save for those 'special' projects and it just cuts like butter!!!
When you get yours, tinker around a little bit. There is a bit of technique involved and can make a world of difference, in both ease of cut and quality of cut. As with most saws, remember to let the saw do the work and you'll be most pleased with the results..
Skipper the Penguin
TwoSkies57 is offline
post #7 of 15 (permalink) Old 03-22-2012, 07:19 PM Thread Starter
Marco's Avatar
Thanks for the input Charles and Bill. I will likely use the flush trim bit on the table this weekend as a flush cut saw will have to be ordered either from the store or online. The reason I haven't used the flush trim bit was that I was wanting to trim the tails during a dry fit then seperate the pieces to apply a torch to all sides giving a nice burn efffect to the grain. I didn't feel lucky trimming the tails unglued so will burn the insides, glue it, trim the tails on the table and then torch the outside to match the effect of the inside. BTW it's just a little footstool that you can see the different sides of and it would be difficult to get the torch to the inside(s) and get a consistant effect. I have heard the burn effect looks great with a poly finish on it so wanted to try it out on something small plus it's for my Ma-In-Law and if it doesn't work out...... oh well!
Marco is online now
post #8 of 15 (permalink) Old 03-23-2012, 05:10 PM
First Name: Charlie
I use a Kugihiki for flush cutting (Japanese flush cut pull saw) and a Dozuki for dovetails and tenons.
The Kugihiki is a thin flexible blade. You can have the handle up so you're not scraping your knuckles while the blade flexes down flat. I've also used it as a jamb saw using a piece of whatever kind of floor I'm putting down as a spacer to give me exactly the right height.
reikimaster is offline
post #9 of 15 (permalink) Old 03-24-2012, 09:30 AM
Jim, every one of the flush trim saws I have tried worked fine. Here is one that should be easy to find: Mini-Detail 7-1/4 in. Pull Saw-MPS10189 at The Home Depot flush trim saw&storeId=10051
post #10 of 15 (permalink) Old 03-24-2012, 10:06 AM
OPG3's Avatar
First Name: Otis
I use Japanese style thin blade saws every day. I couldn't even tell you the name on them (Kawasaki, Yamaha) but they work great. No tooth set means no scratches. Since they cut on the tension stroke (pull) rather than the compression stroke (push) you are able to perfectly create a very narrow kerf. Use them slowly - taking your time and they should last you years of regular use.
hawkeye10 likes this.
OPG3
Tweak everything!
OPG3 is offline
Making an Inlay and Inset Drawer Pull learnexperience General Routing 0 10-31-2011 06:48 AM
Homemade Tenon/Carcass saws TwoSkies57 TwoSkies57 Gallery 0 12-12-2010 11:09 AM
Homemade Tenon/Carcass saws TwoSkies57 Show N' Tell 0 12-12-2010 11:09 AM
Track Saws (plunge saws) kp91 Tools and Woodworking 93 05-17-2010 09:47 AM
Jig for Edge Drawer Pull Inlays Troy_Utah Jigs and Fixtures 9 01-30-2010 07:05 AM
