Kreg Pocket Hole Jig ... Awesome! - Router Forums
post #1 of 15 (permalink) Old 03-27-2012, 09:16 AM Thread Starter
jruimy's Avatar
First Name: Joel
Default Kreg Pocket Hole Jig ... Awesome!
Update from the newbie front:
Got the Kreg K4 pocket hole jig last week after reading a great deal about it. In a word: terrific! It's a lot easier than biscuits and dowels and it's sturdy enough for my cabinet carcasses (3/4" pine).
An even greater advantage that I haven't really heard discussed is that you only have to prep one of the workpieces being joined. In other words, you don't have to drill matching holes in the second piece. That just raised my accuracy by 100% and made it considerably easier to get to true square.
Take a side panel, for example, and drill pocket holes down the width. Then clamp your top to the side panel and drive in your screws. Alignment is done on the clamp without having to drill matching holes. Misalignment? Unscrew and start again. Glue is optional so you get do-overs.
You do require some practice driving the screws. Low torque settings are best and 90-degree clamps are most useful here. You can also use glue for added strength.
Overall, this is a versatile system that I see as having lots of uses and as a replacement for my biscuit joiner and my dowel jig.
So now I'm curious: what are the experiences out there with this jig?
Joel
jruimy is offline
post #2 of 15 (permalink) Old 03-27-2012, 09:20 AM
Cochese's Avatar
First Name: C
I have the K3 Master Kit and have found it invaluable for putting together quick projects. I'll eventually use it less as I master different kinds of joinery, but it was a great buy for me personally.
I put together a table saw extension cart in about an hour with it. If I had used other joinery methods, I might still be working on it.
The 144 Workshop - Ambitious but rubbish woodworking
Cochese is offline
post #3 of 15 (permalink) Old 03-27-2012, 01:06 PM
OPG3's Avatar
First Name: Otis
Pocket Hole Joinery has its place, but it isn't a one-size-fits-all panacea for all joints. I love the screws that Kreg sells - they are really of a good quality. Cheaper screws can be found, but I've found their quality to be lacking. The screws without the #17 tips often cause wood splitting - so I gave-away all of my "non Kreg" screws. The jigs are great and the joint is quick and strong. I use glue if it is to be permanent. Since I build tons of prototypes, the pocket screws are often taken-out and used on several projects. The recesses in the screw heads stay nice if your drivers are not rounded. On nice work with exposed joinery, pocket screws are no match for looks - use dovetails or any number of other joints. My work very often does not need to be pretty, so I use a ton of Kreg supplies and plan to continue so for a very long time!
OPG3
Tweak everything!
OPG3 is offline
post #4 of 15 (permalink) Old 03-27-2012, 03:17 PM
Gene Howe's Avatar
First Name: Gene
Since I bought mine several years ago, there hasn't been a set of cabinets made in my shop without it's use. Always on face frames and sometimes in the box construction.
Nearly every one of my shop cabinets, box, jig or work table has pocket screws in it.
Gene Howe
Snowflake, AZ
Gene Howe is offline
post #5 of 15 (permalink) Old 03-27-2012, 07:11 PM
Marco's Avatar
Super Strong joints which I use on my shop tables, Stands, stool storage and rolling tool stands. Kreg's Pocket Holes and extra 2x4's make for some sturdy stuff for the shop. Besides the shop stuff I use it for face frames and some boxes.
Quick and easy and clean especially if you have the Kreg clamps and dust collection.
[B“It’s not a mistake, it’s a design feature”][/B]
Marco is offline
post #6 of 15 (permalink) Old 03-27-2012, 09:36 PM
N'awlins77's Avatar
First Name: Lee
Have one too, and love it!!
N'awlins77 is offline
post #7 of 15 (permalink) Old 04-27-2014, 12:34 AM
Soccmom9366's Avatar
First Name: Becky
Is there a Kreg 'knock off' joinery system that is less expensive? Just asking.
Thank u,
Becky
Soccmom9366 is offline
post #8 of 15 (permalink) Old 04-28-2014, 11:20 AM
MikeMa's Avatar
The cheapest one I know of is at harbor freight. Your mileage may vary on that one.
Portable Pocket Hole Jig Kit
If your budget is tight, consider the Kreg Jig Mini. I don't do a lot of pocket holes, but I have this one, and it does work well.
Kreg Jig® Mini
-Mike
Visit my woodworking blog: http://madermadeit.com/
MikeMa is offline
post #9 of 15 (permalink) Old 04-28-2014, 12:59 PM
First Name: Earl
Welcome aboard Becky!!
Kreg makes a great jig, and i'm glad i held out for the real think. I talked with a few folks from my church while i was looking and they both started with something else and couldn't believe the difference when they got their Kreg jigs.
While i love my Kreg jig, and shiny new tools--this is one where the function has been there from the beginning. An older K2000 (don't quote me on that) does the exact same thing as the K4, except for dust collection which can be fabricated. The newest, K5, has a front clamp lever but i can reach around back. Take your time and get the good stuff in this case, either used or by saving a while.
My opinion only--others may, and probably will, disagree!!
Edit--the Kreg R3 may be a good stop gap as well...
earl
greenacres2 is offline
post #10 of 15 (permalink) Old 04-28-2014, 03:12 PM
MT Stringer's Avatar
For cabinets, I have been using the pocket hole joinery to assemble the face frames and to attach them to the carcase. The rest of the carcase construction involves dados, glue, staples and screws.
The Kreg jig is just one of various tools that I use. whatever it takes.
Note: Mine doesn't look quiet like the one you have. :-) But it gets the job done, and quickly!
It also doubles as a pecan cracker.
Works Great As A Pecan Cracker Too! Video by mt_stringer | Photobucket
MT Stringer is online now
How to Fill Pocket Hole kawisser Tools and Woodworking 9 10-31-2011 03:01 PM
Kreg Jig N'awlins77 Starting Off 23 04-11-2011 08:19 PM
Key Hole Jig dan morrissette Jigs and Fixtures 8 01-17-2008 01:27 PM
Pocket hole jig hawker44 Jigs and Fixtures 6 10-23-2005 10:19 AM
Shelf hole jig Tony Jigs and Fixtures 7 08-19-2005 08:35 AM
